I hear you with the mig, same thing happens to me with the sparks. I guess a full leather tent over your body/chair might work, but those sparks seem to find every nook and cranny
Burgerman wrote:Do it out in the rain during a thunderstorm. Best at night. Nobody will think you are mad.
HotColors wrote:Nice, another unique design. Nice machine work also. I have some ideas on doing front suspension. I have a CAD file for a truck arm style rear suspension that uses 1/4 midget shocks. Next one i build will have full suspention.
Any idea how complicated or feasible to make a traditional gear box for this brushless motor
Burgerman wrote:I might have made it in stainless. Or alloy. How are you going to stop it corroding? Grease might work.
flagman1776 wrote:Will, I love the drive & your workmanship is impecable.
popschief wrote:Has anyone considered one of thesehttps://youtu.be/O4h-Me5lSOY belt drives?<br abp="715"><br abp="716">bp
popschief wrote:I once worked overhauling Blackwelder tomato harvesters as a winter job. The system they employed to control ground speed was a large variable speed belt drive. In this way the engine rpm was kept constant to adequately power sorting belts, shaker arms and a lifting conveyor belt. The machine weighed approx. 30 tons before the 11 man crew climbed aboard. There were many maintenance issues but the variable ground speed drive was not one of them.<br abp="674"><br abp="675">bp
Burgerman wrote:You do realise that you get exactly the same affect by choosing the same low speed. But instead of using the hi speed, just use twice the volts? No gearbox needed. Your pulse-width controller and the higher volts becomes the gearbox. The same speed and torque as having 2 speeds. Without needing to actually have 2 speeds... Only with BETTER efficiency.
In your case will, use half the teeth on the motor or double the teeth on the wheel. Or whatever gives this ratio as a set. That doubles your torque. And halves the Amps needed to drive. At 96 volts instead of your 48, you still have the same speed as before. And more range... Exactly the same result as a gearbox, but none needed.
The battery will get quite a bit unmanageable. No room for a 30S pack of any valuable capacity.
Users browsing this forum: Gnomatic, LROBBINS, sergey0, slomobile and 228 guests
