Burgerman wrote:Grp 24 sized? Will be about 70Ah and dumb BMS. And the 50 mile is ISO miles. Call it 35.
And their controller is 120A. Not 100 with 120 boost like r-net. Their handheld is basic level. No OEM for the customer...
Burgerman wrote: If I bought one I would toss the BMS and use the pl8v2 charger... Real problem is the width though with the good fat soft tyres. And maybe the length. A rear view isn't pretty.
Burgerman wrote:Not in a month of sundays. Looks like something from 1970. Huge load of stuff hanging out the rear. Too wide with fat tyres. Too long. No known oem programmer. Weighs a ton.
Burgerman wrote:But. If he wants the speed without that saggy elastic band feeling on the controls, he needs the 48v one. And they cant offer that with lead because it cant cope. So that means ordering lithium at the same time?
4k for 100Ah lithium!![]()
You can build 3 packs for that.
expresso wrote: i was told there controller gives out about 150A - they offer another controller also - but i would stick with there own - if i get that far -
Was it more peppy or anything like when going over small obstacles ect?
Gnomatic wrote:expresso wrote: i was told there controller gives out about 150A - they offer another controller also - but i would stick with there own - if i get that far -
Did not know their in-house controller was 150A. If that's legit and apples to apples compared to R-Net 120A, you're getting 25% more power/torque right off the bat. And if you build and put a lithium pack in there, you'll have a battery that can deliver that much current upon request.
After you put your lithium pack in your 646se, did you notice any difference in how the chair handled? Was it more peppy or anything like when going over small obstacles ect?
expresso wrote:
yes i was told 150A about for there own version - if thats true or not - cant say for sure - there website is very dated also - seems to never change so even though it shows 120A controller on there website - i wouldnt be too surprised if its not and may be 150A -
Burgerman wrote:Well if thats the case. But sounds unlikely. They updated that page recently to cover the Dynamic DX2. But remember the chair needs more to start with as its built out of heavy stuff... Likewise it needs more battery too.
Burgerman wrote:Note battery (meter) menu below...
That will allow me to set say 3.35v per cell as 100 percent. (26.8V) and then fine tine until it reads full for first mile or so.
Then set say 3V per cell (24.0V) as the red/end of play.
And set it to VOLTS rather than a fuel gauge.
And 9 other battery meter settings to fine tune for lithium accuracy!
And I can set it to stop the chair completely for safety at (2.8v per cell) 22.4V.
download/file.php?id=5945&mode=view
Because you need a better than OEM to get to it... But it obviously can.
SERVICE appears to unlock the factory stuff thats OEM wont...
Users browsing this forum: No registered users and 92 guests
