curiouscat wrote:6mph to 16mph is a huge jump. Do you drink Expresso? If so wear a helmet, if and when you get thereI've been reading a lot of your posts lately and it wasn't that long ago you were happy to wait for the manufacturers.
BM ever been done for drink driving?I used to get told off in college for carrying tea and driving my chair at the same time. Just because the majority of chair users couldn't drive in a straight line to begin with
Burgerman wrote:Since what you are actually trying to do is lower the center of gravity, adding weight to you or sitting taller with a heavy seat makes it worse.
Adding the 50lb weight you saved into the battery area below the battery is overkill because its sitting below the center of the batteries mass. You will likely need about 25 lb sat this low down, to have the same effect as a 50lb missing battery.
Burgerman wrote:HRO hot rolled and 250 is 250 thou or 1/4 inch. Theres 1/2 inch or 500 too.
Burgerman wrote:No, do it!
Why not hedge your bets and go for 3/16th or 8mm or 10mm plate?
Burgerman wrote:1/8th is 3mm
1/4 is 2/8ths! 6mm
3/8ths is 9mm
4/8ths is a 1/2 or 12mm
Gnomatic wrote:Why not use a lead plate? Higher density
Users browsing this forum: DennisinTexas, duke1, emilevirus and 288 guests
