Would it be problematic ?
shirley_hkg wrote: The longest path amongst the 9 balance leads is estimated 6 feet .![]()
Would it be problematic ?![]()
shirley_hkg wrote: TOTAL : 6 feet .![]()
Burgerman wrote:The cables I use are 36 inches/1 meter long. And another half a meter on the chair. And in the past I used a 36 extension too. So 2 meters. Worked fine every time. It can overshoot voltage slightly for a couple of secs, or balance a little slower thats all.
Regardless of cable length:
1. Dont set balance to begin at 3.300V, or 3.400V. It causes out of balance issues if you charge at a high rate, so set that to start at 3.500V.
2. And for a stored, or a new pack, or out of balance pack, set termination to 1000thC just for 1 charge and then back to 320th to 500thC afterwards. And charge to 3.550V instead of 3.600v. And charge rate quite low.
Burgerman wrote:It is here, the world all turned white.
Burgerman wrote:Nothing. The world is covered with a layer of white global warming and I don't like it.
It was very much time consuming than expected .
shirley_hkg wrote: Finally , the first charge lead is made . It was very much time consuming than expected .
Burgerman wrote:I am in the civilized world. We gave up on old analog inches when I was about 14. I am 56 now! I bought a huge bag of pre glued heat-shrink in every size on eBay.
Burgerman wrote:I never looked at silicone or triangular... I suspect its for plumbing work! It wont self fuse the same.
https://en.wikipedia.org/wiki/Self-amalgamating_tape several types. I use rubber. Silicone is fragile and cuts easy.
Users browsing this forum: No registered users and 256 guests
