Burgerman wrote:We dont know that PG works the same way. OEM is usually all we need anyway. But it may be that if you de dongle the software, it defaults to allowing every level like the Wizard software seems to do. So the real answer may be to hack the PG software in the same way.
If I can do batches of 10, letting them 'soak' on the charger for a couple hrs when finished, I can probably get through them in a couple days, three tops.
Burgerman wrote:If I can do batches of 10, letting them 'soak' on the charger for a couple hrs when finished, I can probably get through them in a couple days, three tops.
They dont soak. Done is done when it says done! Thats when current falls to termination point on the PL8.
..... charge every single cell to 3.600 volts, and leave on charge afterwards for 2 hours minimum to soak. You can do this in parallel in big groups of say 10 at a time.
Burgerman wrote:If you can count on your fingers you dont need scollard to add it up for you!
You just make 8 piles of cells that add up to the same amount lost total approx.
Burgerman wrote:Add up ALL cells, divide by 8... Thats what you are aiming for in each group.
Lets say you are making a 4P and 8S battery... It lost 1448mA total!!!
Divide by 8 = 180mA PER GROUP!
So a 3mA cell and a 60mA and a 15mA and 100mA cell, makes a 178mA total for that one pile of 4 cells. Thats close to 180 right?
Now make 7 more!
* IF you find a cell that has say 300mA lost, or say a fair bit more than the rest, either don't use it or retest it. But its unlikely. All cells must be charged exactly the same way with same settings.
brianpile1 wrote:Hi
I have just taken delivery of a new Frontier V4. I aim to do the lithium conversion once I have knackered the supplied MK gel batteries.
My wife needs to connect the charger for me. Obviously at the moment this is easy through the normal connection in the hand control unit/pod. I want to make the lithium batteries as easy as possible for her to connect. Stupid question, [1] - can the lithium batteries be charged up via the hand control unit, once suitable adjustments to the wiring loom have been made?
Stupid question [2] - the weight distribution of the chair will obviously be affected by replacing the normal batteries with lithium at roughly 50% of the weight of the gel batteries. So why I don't I leave the now-defunct gel batteries in place, and make up an external pack for the lithium batteries, which I can then hang off the back of the wheelchair. This would have the added benefit of shifting the c.of.g rearwards a little, as well as putting them in a place easier to connect to the charger,
What do you think BM?
brianpile1 wrote:I thought so. Too easy/unfeasible! Thanks Gnomatic and BM. Sorry to be thick, but do I need an electrician to wire me up a new power supply, and direct to the charger, or via a normal power socket?
Gnomatic wrote:brianpile1 wrote:I thought so. Too easy/unfeasible! Thanks Gnomatic and BM. Sorry to be thick, but do I need an electrician to wire me up a new power supply, and direct to the charger, or via a normal power socket?
You're not thick, I'm still learning too. I'm just a bit farther down the road than you.
You're in the UK right? CoolIce PSU's should work for you
http://www.coolice.co.uk/cfs/coolice-psu-s.html
I have a friend who is an auto- electrician, once understand this stuff,
Users browsing this forum: LROBBINS, shirley_hkg, Yennek and 91 guests
