http://www.wheelchairdriver.com/charge- ... om-car.htm
JoeC and other heavy users or sport powerchair users. I just tested my charge from car leads in anger as my batteries were down to about 12.1v (24.2) after going on a long dog walk! They felt pretty dead and I lost lots of lights... So I started the van and connected up one battery at at time via the leads and the socket in the van as I drove.
Each battery charged at 100 amps exactly to begin with (clamp meter) and this gradually dropped over the next 15 mins to a more sedate 30. And stayed there for a bit and then as they became charged (14.4v dead on vehicle output voltage) the current dropped away to around 2 amps at which point they are around 90 percent charged or more. Safely. And it takes a surprisingly short time. From all but dead to 90 percent in under half hour. Of course there are 2 so you need to do both and measure the current so you can stop at the same point - say 2 amps to keep them equally charged.
This was all with AGM Odyssey batteries. Which is allowed by the manufacturer. After all there is another one fitted to the van anyway! It gets that same current everytime you fire it up. Same with the deep cycle Optima. And any Starter battery or deep cycle/starter. And as an authorised Optima dealer I can tell you that thats also perfectly safe and expected and not unusual.
I tried it with less deeply discharged batteries and its unbelievably fast.
I also tried it with some MK Gels.
They take longer because the voltage is easily "pulled" up to 14.4 and less current is needed to do so because of their inferior higher internal resistance. Probably takes twice as long. But its still perfectly safe practice according to MKs area rep. Then get very slightly warm. But below the 50c that the manufacturer specifies as max.
Of course you need to charge them individually with a proper 3 stage charger to balance them every day/few days too.
So no charger needed and very easy fast charging in the field. Literally in a field in my case!
