Which Powerchair Controllers are best? (Penny & Giles, DX )
Discuss anything related to Powered Wheelchairs in here! Battery, or charging problems, storage, tyres, repairs, reviews, questions, moans, praise for people and companies where its due etc!
POWERCHAIR ONLY: www.wheelchairdriver.com/Quickie-Sunrise-f55s.htm
Postby Burgerman on Thu Mar 11, 2010 1:36 pm
http://www.wheelchairdriver.com/penny-g ... s-best.htm
Just updated this page in light of what JoeC told me, Dynamics Tech guys and P & G guys told me. Plus I then did a little testing!
But I only know about these two systems. So Anyone with any info (or corrections?) to that page or about other systems such as prides own or the one used on the Quickie powerchairs (Qtronics???) etc.
Thanks!
Re: Which Powerchair Controllers are best? (Penny & Giles, DX )
Postby JoeC on Thu Mar 11, 2010 5:21 pm
Qtronix is just a re-badged P&G Pilot+. The programmer is the same, the connectors and plugs are the same, as far as I can tell only the mold they used for the joystick housing is different. Oh, and any stickers or decals- which is what I meant by re-badged.
In my experience, a lot of the Dynamic DX module that I buy on Ebay were originally installed in Pride chairs. Some of these chairs are rated for users up to 500 or 600 pounds, so they really couldn't cut corners on the electronics or the chair wouldn't be able to get over the threshold out of the showroom.
It should be noted that Invacare owns Dynamic, and some of the controllers in Invacare chairs are based on controllers you see described on the Dynamic website. The Gearless Brushless controller appears to be made or designed by Dynamic, and some of the MK-5 controllers I have seen on Ebay appear to be based on Dynamic Shark controllers (a lower end model that's more on par with the P&G parts).
JoeC
Postby Burgerman on Thu Mar 11, 2010 6:18 pm
I will add this info to the page and a link from the page to this thread.
Will the PP1 programmers work with the Q-Tronics systems directly then?
I have a guy emailing me asking what he needs to remove some walls. He also plays powerchair football and has a 40 percent max wall in reverse speed. So presumable he needs the OEM software to set these all at 100 percent.
Postby JoeC on Thu Mar 11, 2010 6:25 pm
I already emailed him back, and let him know that he needs to find a shop that can move the walls for him, since PP1a and PP1b won't do that. It's true, the PP1 programmers work with the Q-tronix modules, they are exactly the same as a P&G Pilot+.
We had exactly the same problem with someone on my local team- he was limited to about 50% reverse, and it was a huge disadvantage. I think his turn acceleration or speed was also limited to 75%. It was a big improvement when we changed that!
When I called someone (wish I could remember if it was Quickie or P&G) to see if there was any way to move the fences out farther, to get something like 200% acceleration (a half second ramp rate for example), and their exact words were, "It's a wheelchair, not a carnival ride!"
JoeC
Postby Burgerman on Thu Mar 11, 2010 6:32 pm
I also just emailed him before I read this telling him he needs the OEM level programmer. Which I have here. Its a S-626 chair by the way. Did he email you too?
Postby JoeC on Thu Mar 11, 2010 6:50 pm
He did email me, and I replied to him earlier this morning. We probably told him the same thing. The guy on our team who just upgraded to a P200 with Dynamic DX controller has his old broken S626 with a perfectly good control module in it, with the walls moved appropriately and the programming already proper for soccer. I offered to put them in touch if he just wants to buy the module, since I assume that two-way shipping across the Atlantic won't be cheap or fast.
This is a side-topic, but the S626 broke down beyond repair when the aluminum/magnesium wheels had the hub keyway worn and broken by poorly fitted steel keys. The output shafts of the motors were also badly broken, and the wheel eventually fell off. This lousy connection between the motor and the wheel is why Sunrise immediately created the S646 and S646SE. Sure he could get new motors and wheels, but for less money we were able to upgrade a used chair to an even higher standard of driving performance.
JoeC
Liber-T Medtech
Postby JoeC on Fri Mar 12, 2010 12:26 am
Worth a mention!
http://www.libertmedtech.com/controllers.html
It looks very very different from other controllers that I have seen. It does 220 amps to the "traction motor" and 105 amps to the "steering motor"- for multiple minutes at a time. Yet it's controlled by a joystick- this may be the exact controller for the one who wanted to make a 4wd center-articulated offroad chair.
I came across this chair when a friend asked me to help her look for a more suitable chair that insurance would pay for. I remembered a couple years ago drinking with a student who used one of these:
http://www.nextmobilitynow.com/power.php
Still have a scar on my ankle from all of us trying to get into the elevator after so many beers! It was a beast of a chair, but I don't remember it driving in a radically different way from other chairs. Now that I see these data sheets, I'm very curious to see how that chair's drivetrain is put together.
JoeC
Postby Lord Chatterley on Fri Mar 12, 2010 12:46 am
Looks like the Dynamic DX2 90 is the one to go for if you face a lot of ramps and steep inclines. Thanks.
Lord Chatterley
Postby Burgerman on Fri Mar 12, 2010 6:32 pm
I added JoeC useful comments to that page too.
As well as making any chair potentially better on ramps, slopes, thresholds etc it means real torque is possible with 8mph motors. That is the reason I am retrofitting some 8mph 4 pole motors to my own all terrain/in/outdoor homebuilt chair on my site. Time and money allowing!
But that 8 mph thing will still only be a real success with
a) Decent Odyssey, Optima etc AGM dual purpose deep cycle and starter batteries. Deep cycle only, and Gel batteries like the MK batteries just dont allow that amount of Amps anyway. Which is why ALL existing chairs that do 8mph or more lack torque and they get worse as the batteries discharge and age. Its a combination of battery capability and controller output.
b) The group 24 / 34 batteries will obviously suffer range problems still due to the heavier current demands of the controller/8mph gearing/my programming.
But I have room for 110 amp hour batteries and still keep chair looking exactly the same. and have fast charge capability both at home and from my van... So I accept that.
Postby CPguy on Mon Apr 26, 2010 8:22 am
It just came to my attention that Sunrise Medical apparently uses uses a customized controller from Delphi (a large automotive supplier) on its "Quicke Groove" models. They seem to be quite secretive about technical data as I only found limited information here http://delphi.com/manufacturers/dti/ava ... nd-module/ and here http://www.quickie-power.com/groove_be_ ... %20NEO.pdf .
Does anybody here have technical info on the controller?
CPguy
Users browsing this forum: Google [Bot], LROBBINS, White Lightnin', Yahoo [Bot] and 4 guests
