Handicare I have never had anything to do with or seen any of their chairs other than on the net.
They are, presuming you are talking about the Puma chair, 25 inches wide (6mm wider than my fat tyred one) and 2 inches longer. I am presuming the length measurement includes footplates.
Group 24 batteries (biggest offered) and 6mph are the only sensible options here of the speeds and battery sizes. It also has 250mm (10 inch) casters which are correct for sensible outdoor use in the mess that is the real world. And a fairly low 17 inch seat height. So well worth a look provided that it has 80 amp controller minumum if you are an active 13 year old girl, or 100amps (or more) if you are a heavy busy adult in a hilly area!
And if a proper programmer is available to buy.
http://www.wheelchairdriver.com/powerch ... amming.htm The Otto Bock 600 is much the same setup and layout as the above. (no not actually tested but have examined one in real life) And also worth a look.
Permobil I will take a look at properly someday, but they mostly just do front and mid drive or 6 wheelers and seem more concerned with "colour coded" wheel trims and seating that does tricks than outdoor function and capability!
The only indoor / outdoor chair they do that isnt front/mid drive (which both offend my mechanical sensibilities personally) ios the C350 TS Which is narrow (about half inch less than the two above which is good) and the same length at about 42 inches but it uses smaller group 34 batteries (bad news!), and it can do so since its also slower too (also bad news). So already I would have ruled them out.
No idea what controller it uses as they dont want end users knowing about any technical stuff! Hence I ignore permobil mostly!
Maybe someone that owns one or knows more about them can comment? (Chris Parks, are you reading!?)
There are 130 amp controllers available now from Penny And Giles such as the R-Net ones. Never saw a manufacturer other than the "Tank Chair" use one yet . And it needs much more.
Can only suggest you ask them all lots of questions about motors, speeds, power controllers and programmers, test, try and have a good look and report back here!
Diid you look at the pride quantum r4000 or r4400 chairs?
Burgerman.
