PowerChair Programming
If
you are a Full Time Powerchair User then you really should know about this
"programming" stuff! It makes a world of difference and its actually
essential if you are to get some proper control.
As the permanent "end
user" of your Powerchair you really need to set up your programming (its hidden
menu settings) to suit YOU. Not the generic feeble minded old /
and disabled person that they had in mind
at the factory!
They have to set
them up like this to start with because they do not know how truly incapable the end
user will be. Like you wouldn't give your 92 year old grandma a 500
motocross would you?
If you do reprogram it will
wonder how and why they made it so bad! And if you don't then you will
never know how much better and easier to control your powerchair could actually
have been. The difference is simply huge. I have a steady stream of
Powerchair users that leave here simply amazed at how much more control they now
have. Especially on the "slowest" speeds.
One of the biggest problems I find is that once you are
a wheelchair user everyone treats you like a fool!
So getting hold of a suitable programmer for your chair for
example can be a big problem. Everyone in the "industry" seem to be huge "Safety
Nazis" and are all terrified of a wheelchair user actually getting hold of any useful
information or tools. Or in this case some "control" over their mobility. Or allowing them to modify
anything especially programming for themselves.
It doesn't matter that I have forgotten more about
powerchairs and engineering and physics in general than most powerchair
manufacturers combined, or that I am quite prepared to accept the full
responsibility for my own actions! The manufacturers don't want to "allow"
it. Car manufacturers will sell you parts
(and tuning parts) etc without any arguments. Why is the Wheelchair "industry"
any different? Anyway just to warn you about what we are all up against...
Its the same with the powerful
Powerchair Programming Tools. There are several "levels" of these
tools. Generally depending on the powerchairs manufacturer (or rather
manufacturer of the control
system) The programmers that I refer to on here are the common Penny &
Giles Pilot Plus controls.
But the SAME settings (give or take a few) are available on all
modern control systems whoever makes them. They may have different names, be
laid out differently but they are all basically the same. Most powerchair
manufacturers also use one of a very few control systems brands. Although often
rebranded to make you think they are their own.
The actual tools
needed may be a "hand held box" or a Software Program that runs on a PC with a special
connecting lead
that connects to your Powerchair to the PC.. Or may be available in both forms.
There will be an END USER (Dealer) programmer.
This you can usually buy easily enough. Or the average tech guy or place that supplied
your Powerchair will have one,
They allow you to adjust a some basic parameters within "walls" and they can sometimes help
set up a few basic (easy to understand) things. But in general they do not give
the USER or dealer anything like enough control of the important settings. I had one here
for a week about 10 years ago. A "DEALER / END USER.
In Penny and Giles speak this was the PP1a version. I gave it away...
There is usually a Service Centre or
Technical Repair Guys Version This covers everything we will need to
change to get some accurate control over your Powerchairs steering etc. Its
difficult to persuade anyone to sell you one of these. Which amazes me! You NEED
one to correctly configure your powerchair. Its simply not possible to "take
charge" and get rid of all the delays and accelerations without one. This means
all your door frames will be damaged since you cant control the chair
accurately. And yes they are ALL like this. In Penny And Giles speak
this is a PP1b version.
There is also
usually an OEM (Original Equipment Manufacturers) version. It has a
few more settings still although not many and none we will be requiring!
But you don't have to use them. So either the PP1b or the OEM version are
ideal. Sometimes there are just two versions. Depending on system.
The BASIC "END USER" PP1a is truly a
waste of everyone's time and money if you are looking to get some proper control
- especially low speed accuracy through doors etc. Because it doesn't allow
access to a level called the "engineering menu" which is to my mind absolutely
essential.
The first section here (below images) is the (important) settings and tells you
what each setting actually does and why your powerchair has a mind of its own.
Later on is the second section which is the more important part, and it is only
AVAILABLE on the PP1b and OEM version programming tools.
First some quick screenshots... The Penny
and Giles PC based R-NET controller looks like this below: It a lot
"longer" than this though! Changing your powerchairs settings is as easy
as this. Just understand WHAT you are changing and change one thing at a time!
Before you do this Save a copy of your original settings. Or if using a
hand held device write them down! Then you can always revert back as
needed.
PC Based Pilot Plus (and a bunch of other
systems) programmer. Here's what it looks like. Not rocket science is it?
The problem
with most stock bought retail powerchairs is that they are programmed to suit my
92 year old Granma. In some cases so severely handicapped by programming that they simply wont move left or right
on thick carpets or grass at all. And they feel sluggish and lacking any power
or urgency. Most powerchairs that I have tested or repaired were exactly the
same... And thats almost every manufacturer. The biggest problem is
usually a delay in steering especially at low speed. And worse a delay in
STOPPING the thing turning once you choose to. Thats easy to fix!
That includes most of the "best" top end powerchairs available. And
I have yet to find ANY powerchair that can be driven around and through tight
doorways etc with any confidence or accuracy without removing all of the delay
and acceleration settings in the programming setup completely. If this
makes it too sensitive then that because you must reduce the turning speed too!
Then it will go where and when you point it.
Its not the manufacturers fault exactly since they have
to send out "safe" chairs that can cope with kids, mentally retarded users,
nurses and carers, people catching the joystick while serving your food in a
restaurant etc. They don't know YOUR capabilities. So the
chairs are purposely "detuned" for a dismally gutless lack of response to
"commands". The trouble is that I don't want that! And if you are anything
like me you don't either.
They ALL have so much "turn
acceleration" and worse - "turn deceleration" programmed in at both the
"fast" and
"slow" ends of the speed ranges, that steering through a doorway becomes a matter
of faith and luck and damage to the house and your chair! And its totally
unnecessary.
I kid you not
they really ARE that bad. The chair you are driving right now is this bad.
You just learned to accept it. And got used to it. You think its normal
because "all" chairs are like that... Wrong!
Mine (all 3) are absolutely instant,
controlled and accurate.
However there is a downside. If you choose to program all of that awful "Elasticated"
& gutless steering out, then you will have a powerful chair that JUMPS on
command. It will be instant and follow the joystick accurately. Even on the
slowest speed settings. Much like a model Radio Controlled Car. That's
absolutely great! Its a revelation to use. Until you catch your sleeve on
the joystick by mistake and take out several people! It isn't quite that bad,
but the chair WILL do as you tell it. Even by accident.
Because rather than move slowly for a few inches it will literally leap in one
direction or the other and hit people or tables. You have to GUARD the joystick
in public places or switch the chair off. If not and some kid grabs it (as they
do) for e.g. you will literally run him over before you can do a thing about it!
This is why they don't come like this... Of course this is all for you
(not the factory) to decide. Only you know your own abilities.
This module above (or one very similar
depending on the manufacturer) lives under your powerchairs seat. Or somewhere! This is the
power controller, that controls the current and drives your powerchair. Its this
thing you are actually programming. This is where the computer lives! You do it
Via the joystick pod generally.
That said, BELOW HERE is what each setting actually
does:
Programming
DETAILS! --
Settings... What they do. And why your Powerchair
doesn't steer properly!
Normal USER settings (These are in the BASIC END USER Programmer)
a) ACCELERATION.
This is the rate of forward acceleration. like when you jam the stick forwards.
Normally this is set to a low value. I set mine to 100 (max). it feels too much
at first. After a week you will want more. At least I do. You choose what you
are comfortable with. If you don't choose 100 then you will never actually
achieve the 100 or 80 amps that your controller is capable of during simple
acceleration. Unless going up a ramp or on a steep hill.
I know this because my trusty clamp ammeter tells me so. And
even then only for the first few feet. Does not alter speed or anything other
than forward acceleration. Your Joystick then does this (you get to choose!)
If a waitress catches the
control stick or small kid grabs the control you may well run over someone.
You don't HAVE to jam the stick
forwards though. Its like a cars throttle. It goes both ways. Contrary to
the opinion of many, accelerating hard does NOT use more battery power.
Accelerate twice as hard and you use twice the power. But for half as long to
achieve the same speed. It takes the same amount of energy to achieve your end
speed of 6 or 8 mph no matter how fast you do it in the end. Basic physics.
b) DECELERATION.
This is the rate of slowing down when you are travelling
forwards fast and you return the stick to the centre. I set mine to 20, (from
100) which means
it doesn't slow very fast. It does still slow down fast when you pull the stick
right back as this is not effected here. The reason I choose a low value is because its smoother and you can
let go for a split second without sliding forwards off the wheelchair or slowing
down too fast while you
open a beer or whatever... Decide if you want yours to slow faster or slower and
adjust to suit your taste.
c )
TURN ACCELERATION.
This is one of the multitude of settings the manufacturer chooses
that makes the chair safe and smooth. And very hard to control! There are a bunch
of different turn acceleration settings in this list. This particular one causes the right
or left turn you want or the "correction" you
just tried to do at speed to respond very slowly at first. So you push the stick left or
right and at first little to
nothing happens. Its a timed delay.
If you then don't add
any more turn on the stick (you keep it with the same amount of turn) the
wheelchairs turn begins to
accelerate or actually happen just as it should have done from the beginning!
But as a user it just feels like nothing
much happened at first and that door / tree is getting closer so you intuitively turn
harder! Now all hell breaks loose because the first correction was correct
all along you just needed to wait... and you just added some more, so you now
change direction more than you wanted to do. And are heading for the door frame
or tree at 6mph. So to remove all this turn
acceleration completely and make the "turning" truly proportional to the control
stick just set it to 100 percent. That is off. Zero delay.
This way you get
instant and positive response that stops you from over controlling while you
wait for the chair to do something... In other
words the powerchair turns by the amount you tell it and does so when you tell
it!
This effects the high speed end only.
It will still be delayed on / at all other speeds. That setting that makes this
work at slow speeds comes later.
d) TURN DECELERATION.
You remember that door frame that the setting above made
you aim at by mistake? Well this makes sure you hit it. You realise that you are aimed at
the door frame so you try to stop turning towards it. But no, this setting means
that the control stick
being returned to the centre or even the opposite direction has no immediate
effect!
It delays the turning and continues to turn AFTER you wanted to
stop! So it keeps on turning left or
right while you panic and lose a few more knuckles on that door frame! Who invented this stuff, To turn this off
as well you just need to set it also to 100. That disables it. Now when
you want to stop turning the chair agrees with you and it stops turning when you
tell it to. Cool or what! Keep your knuckles! set it to 100.
Downside of the above two settings That waitress again. Now if she
catches the joystick it will jump left, right and forwards! So you need to be very aware
of what's happening around you. This effect the high speed end only. The five
LED speed setting on a typical Penny and Giles Controller and has less effect as you choose
the slower speeds. The settings
that effect that are also later on in this list...
e) FORWARD SPEED.
Maximum speed depends on this being set to 100. The chances are your chair will
be set to 100 already unless you bought it used. The thing that changes maximum
speed is the motors gearing, So you cant make it faster top speed like this.
This only effects the maximum speed (on the five LED light speed setting)
f) MINIMUM FORWARD SPEED.
Effects full speed (stick fully forwards) when set to the number 1 speed setting
One LED lit on P and G. Pilot Plus for eg. The best balance seems to
be 30 as I see things. Fast enough for moving about slowly indoors. And safer
when that waitress is about! Because it will still have some speed of
response and power once all of these
settings are changed even on the lowest speed setting.
g) MAX REVERSE SPEED.
Sets the fastest your powerchair can go in reverse. On the
fastest speed setting. Just like a front drive wheelchair going forwards a rear
drive one going backwards is inherently unstable... So don't set this above 60
(that's what I use) or one day your chair will try and spin around and go
forwards and tip you out.
) Go on ask me how I know!
h)
MINIMUM REVERSE SPEED
Sets the fastest you can go in reverse when your speed
setting shows 1 LED or its slowest setting. It feels balanced when its set to 20
i) MAX TURNING SPEED.
This sets the rotation speed of your chair when your speed
setting is at the max - or 5 LED lights. Its a compromise. If you set it too high
the chair spins on the spot very fast. Which you don't need. If you set it too
low you have very little steering response at high speed. After a lot of testing
I use 45. You need to experiment in daily use to get this the best for
your particular chair. It will need to be set lower than it was before if you
remove all the delay/acceleration above. Possibly much lower. Test!
It controls the RATE your chair turns. Not the delay.
j) MIN TURNING SPEED.
This effects the rate of turn at the slowest setting or with the
1 LED lit on a typical Pilot plus / Penny and Giles system. Mines set to 25.
k)
PRESET?
NO!
if you do everything goes
back to some default settings and we really don't want to do that...
l) SLEEP TIMER
Nothing is more annoying. Mines set to 0m Why would you want it to go to sleep?
Joystick becomes inoperative and you need to turn it off and back on again. Some
may want this. I don't.
m) JOYSTICK THROW . Should already be set to 100 leave it like this or some
of the stick movement has no effect. Don't know what the point of that could
really be unless you have very limited hand movement.
n) STEER CORRECT
Set to 0. Used to compensate for the chair tending to go left
or right if both motors are not equal. Personally I would rather fix the motor
problem!
o) READ TIMER.
Go on you know you want to! Mine reads 4405 hours on this chair - the other two
read a bit less. email me and tell me how many yours says and how long you have
had your chair. Not sure what it actually times because it seems to go up slower
than the actual time you use your chair. Maybe it times only above say half
power or something. Anyway its interesting to compare!
burgerman@ntlworld.com
p) READ FAULT
LOG Try it. There will be one or two. most mean nothing much other than you
turned it on without the joystick centred or with the brake on, etc. I will post
a list on this page soon or the read ERROR codes and pod flashing light codes.
End of basic "user" programmer settings.
These wont have made much real difference alone. You also need the following:
Hand
held version is easier to use when out and about!
Start of Engineering based programmer menu:
Sadly the above is all you can do with the BASIC END
USER programmer which leaves most of the important stuff unchanged. To set these
and be able to steer properly you need a PP1b or "Engineering" level programmer.
Or an OEM programmer. If you have or can get, buy, or borrow one then this is
what these settings do:
Engineer Menu (only on the PP1b and the OEM programmers, as well as
certain PC software plus programming + lead solutions)
Change the settings here incorrectly and you can make the
chair dangerous and burn out motors, wiring and controllers. And its obviously
going to invalidate your warranty and scare certain other more "corporate"
online so called "experts" to death! So don't do it then! Your choice. But
this is the part that turns your gutless ill steering imprecise powerchair into
something completely usable!
a) ENGINEER
MENU? Yes! This is important if you want to regain any semblance of
proper control. As
above there are yet more programming options that allow you to remove all the
awful delay/accelerations when turning or trying to stop turning, in this case
at the slower speeds as well.
b) CURRENT
LIMIT. This can limit the maximum current the controller supplies to your
motors. If you have a 50, 80 or 100 amp unit then it should already be set to
the max. 100A in my case. I did find one chair that was set lower apparently
because of a continual overheating problem by an "engineer" turns out that the
"engineer" had set the temp fold back too low in a previous session... of which
more later. Can be set low on purpose to limit maximum torque (power) for
kids, mentally retarded etc. Otherwise set to maximum or curbs, thresholds and
ramps become pretty difficult. Maximum isn't enough anyway!
c) MINIMUM
CURRENT, Mines set
to 100. Controls maximum current allowed. That appears to make no
sense does it? That's because its the maximum current delivered
with 1 Led lit on your controller or at its slowest speed setting.
So less than maximum gives low power when set to slow speeds. (less torque
available which is "safe" but useless for ramps, steering etc) You WANT power
but not speed to manoeuvre indoors on slow settings...
d) TEMPERATURE FOLD BACK?
As the controller has to control a large amount of
energy it gets hot. Its not 100 percent efficient. So climbing hills, especially
on a hot day for example can cause the controller to get hot. To protect itself
it then drops to a reduced power level (your chair feels gutless!) until it cools
sufficiently to go back to normal. The standard setting is a very conservative
55 degrees. Depending on powerchair model and control system.
Well the manufacturers don't want to be replacing these controllers
under warranty so its a good safe figure "for them". Its too low for me. Thing is it causes me grief because I am an animal!
It cuts in and slows me down in summer if I am working the powerchair hard. I
have had mine set to 70 degrees C on 3 different powerchairs that have worn out
10 sets of motors (not through heat but wrecked mechanical couplings / gearboxes
etc) and 15 sets of batteries in about 12 years and never had one
controller fail yet. The controller doesn't measure motor temperature just
its own temperature. Motors don't get very hot anyway.
So if you don't want the thing permanently slowing you in summer
turn this up and accept the small extra risk of failure. Your call! Life's too
short for a safety Nazi Manufacturer "safe" settings... I accept the
small risk and don't care if it fries! In 12 years of abuse none have done so
yet. If you are careful and worry about these things leave it alone! Or
raise it a little.
e) TIMED FOLD BACK.
Mines set to 15 seconds. This drops the maximum current to a (chosen elsewhere)
lower level after 15 seconds if your motors are stalled. It is supposed to
protect the controller, but more so the motors and wiring from excessive current
burning them up if say you reverse to a wall and try to push it down... 15
secs is plenty to get up a curb, or to wheelie away from a standstill. Nothing
else uses that much current other than turning on a ramp, or thick carpets or
grass. Standard setting is 30 secs on mine which is too long. Your
choice!
f) CL (CURRENT LIMIT) PERCENT.
When the above stall condition
happens (or when overheat happens as set above) this is the amount the current is limited by
to allow cooling to happen. Standard setting is 50
percent on many chairs. Its a sensible figure. Mines set to 80 because I have more sense than
to overload stalled motors for more than a few seconds. If I do I smell burning
or hot wiring then I would stop murdering it! Most are set much lower so your chair goes
very sluggish...
g) MOTOR COMPENSATION.
If in any doubt DON'T CHANGE THIS!
This SHOULD be set correctly by the manufacturer. Unfortunately that isn't always the case as explained to me by an
expert in control systems at Penny and Giles Controls who actually make these
control systems.
Many Powerchair Manufacturers only make frames and seats.
Everything else such as control systems they buy in. And
this compensation
figure not set in stone
either, unlike a certain other so called online "expert" would rather have you believe.
My original 12 year old F55s powerchair was sent out to the public for years
with a compensation setting that was way too
low for the old 2 pole motors that it was fitted with. Original Compensation Setting
was 40m/ohm. With this setting the chair would barely respond to the joystick at
all. It was
frankly almost unusable. And the reason that I was talking to Penny and Giles
controls www.pgdt.co.uk in the first place.
They advised my to turn up the compensation to
double that figure. At least. They advised 80 to 95. I finished up at 120 m/Ohm.
At that setting it was much more responsive and controllable without being
jumpy. If you have an F55 with 2 pole motors you can try this. If you have 4
pole motors 40 to 45 is correct! More makes it very dangerous. So only try this
if you know which motors you have.
Most Wheelchair manufacturers know little about this stuff so it
seems, they just buy it in. Or have it made and "branded" for them. They know how to make all the metalwork and bracketry
that they sell as wheelchairs. (heavily and badly mostly!)
Changing these compensation setting will not make your chair
"faster" because you can only get your 80 or 100 amps maximum
depending on your controller and no more. But it
will allow you to actually "access" the 100 amps when you want it! To
manoeuvre. If
you have an early 2 pole motor F55 powerchair you can (and sunrise advise) you
to retrofit the later 4 pole motors. And since the compensation setting for these is
40 anyway (the same as the old chair was originally set to) they work massively
better! For most powerchairs it will already be correctly set.
If you have 4 pole motors already
then you can try 45 to make it slightly more urgent in control response if you
want a little more suddenness in your chairs response, I use 50 because I am a
hooligan and I am fat which damps the chairs response somewhat! Anyway all at
your own risk of course.
It works like this... The larger the number you use the more
responsive the chair is and the more jerky it becomes. The smaller the number
the more smooth and gutless and less urgent it becomes... Change it in small
steps ONLY and test for a day or so... Or leave it alone. Its supposed to
match the motors Impedance. But they don't always get it right.
h) BATTERY MENU.
Unless you are using some strange batteries or different resistance cables I
would leave this set to stock settings which is actually not set at all on some
chairs!
i) GAUGE CALIBRATION.
This allows you to fine tune the battery gauge. its set at 100 which is great
for the stock Sonnenschein / MK deep cycle batteries that most use. I use some Hawker
Odyssey AGM batteries because I like wheelies and you get less voltage drop
under load and they can be safely charged at 30 amps+ (90 percent full in less
than an hour) they have a slightly higher charge voltage but a very slightly
lower voltage in use. My gauge often reads a little low when in fact this is
normal for these types of batteries. I could correct that here if I wanted to,
but as I know what's really happening I don't bother.
j) PARK BRAKE TRIP
should be yes. Although it doesn't seem to make the slightest difference it
trips anyway.
k) FRONT DRIVE
No obviously. Uses a different algorithm for the naturally unstable front wheel drive
powerchairs. And you wouldn't want one of those things. Ever driven a fork lift
truck?
l) FAST BRAKE RATE
mines 100. If I jam the stick back its because I want to stop fast! It
just locks up the wheels. Choose whatever makes you happy!
m) SOFT STOP .
yes. Slows you down sensibly if you turn it off or pull the cable out. Stops you
falling out!
n) SET INHIBIT:
Active short YES or leave it as it is.
o) PROFILES:
I have none 0 -- not sure why you need them. If you are reasonably
competent and your chair is PROGRAMMED CORRECTLY you will only need one profile for
everything. YOUR CHOICE!
p) SWAP MOTORS.
Don't. It makes everything reversed and is very confusing. Unless you turn the
seat to face the other way... Try it for a laugh but don't blame me when
you break your legs.
q) BRAKE VOLTAGE
12 -- don't try 24 you will probably fry your brakes electro magnet. At least on
MY chair.
Leave it at whatever the manufacturer chose. IF YOURS SAYS 24 leave it there.
DON'T CHANGE THIS
r) MINIMUM ACCELERATION
these next few setting make a huge difference to controllability at indoor
speeds and when set to the lower end of the speed range (1 LED) I set it to 100
so it goes when I tell it to and not when it decides later on.
s) MINIMUM DECELERATION
Same as above 100. I want it to slow or stop when I choose to do so. Not a little later on when it
feels like it.
t) MINIMUM TURN ACCELERATION .
This is the same as the Max Turn Acceleration in (C) above but it causes a
delay in steering input at the slow speed end of control. Set to 100 to take
back proper accurate steering control and get rid of the delay! Less than
100 just means it doesn't turn
when you do or at least as quickly as you do. So you add more turn. Then it catches up later as you loose 3
fingers on the door frame.
u) MINIMUM TURN DECELERATION
As above only this time it keeps your chair turning long after you chose to
return the stick to the centre! If your car did this you would be killed. This
effects the slow speed response only. After these changes you will be amazed that your
chair will steer positively on thick carpet and on the slowest settings...
Set to 100 to get rid of the damned thing forever. Then your
chair will directly follow the joystick even on the slow setting.
v) CLEAR TIMER .
When you fit new motors, or brushes or batteries or whatever it can be useful,
But why not just put the date on the components and write the current hours next
to it as I do in cd writing pen...
w) ERASE FAULT LOG
What it says! After you fix the "fault" as such.
x) PRESET ENGINEERING MENU
No! You will be back to default setting whatever they may be.
Not all of these settings above will suite you, but they are what works best for
me -- the idea is that you understand what does what!
There are some more lower level settings
too on some software (OEM or "C" programmers) but they are OK as they are. We
only need B programmers, A (PP1a) is useless, B (PP1b) is ideal, C (OEM) is also
fine but does more than we need here.
I give out this hard won information because I know how a badly a
stock programmed powerchair performs compared to mine (yes they are ALL
like that even yours!) and wish to help
as many people take charge of their own lives as possible. It will of
course upset any corporate types, Safety Nazis and the sort of people that worry
about Warranties. However life's far too short to have your abilities curtailed
by all the "normal's" in society. Ignore them and do
your own thing as I do. AT YOUR OWN RISK OBVIOUSLY! Its your choice and
your right.
And finally an email I
received after re-programming a young lads powerchair for him by post... He
mailed the controller and I set it to my preferred settings (another Sunrise F55
Powerchair - a known quantity):
"Hi John,
Rebuilt it on Sunday, had it's maiden voyage on Monday.
Bloody hell!!!.......excuse my French, Lukes eyeballs nearly popped out!
It goes like a Ferrari!!
Massive improvement, responsive, quick and stable. Listen to me I
sound like Jeremy Clarkson......lol
Just like a totally different chair I'm really impressed."
And everyone that does this says the same thing. I
personally have set up (re programmed) here at my house with the user present
many, many powerchairs. (Free of course! With a signed disclaimer), Every
last one of them said how much nicer and how much more controllable and usable
it was after we finished testing and finally adjusting things to suit them.
Nobody ever wanted it put back to their old settings.
Unfortunately the vast majority of powerchair users
never have their chairs programmed correctly. Everyone is different and the
correct settings for YOU are the ones you need. Having a "tech" guy blindly
fumbling with your settings for half an hour isn't the answer. Or even close to
it.
It can take months of trial and error and fine tuning
to get the powerchair to its/your best settings. The only way to do this is for
you to have your own low level "full" programmer. And here is the problem.
The manufacturers of these control systems, and the
manufacturer of the powerchairs don't even really want you to know they exist.
God forbid you actually get hold of one. So buying the programmer you need is
very difficult if not impossible for the average end user. How you get
hold of one is the big problem.
What the Powerchair manufacturer SHOULD do is offer
these tools with each chair. Even if it requires a signed disclaimer, etc. for
their own peace of mind. All that's needed is a set of instructions
explaining EXACTLY what effect each setting has. Its really not very
complicated, People are not incapable. Give them the chance to CHOOSE their own
settings and own risk levels.
Detailed PowerChair Only Menu |
TOP END Control Systems
