JoeC, how did your new 25 Amp charger work out?
My dual 12v isolated one turns up tomorrow. (20 amp total - 10amp x 2 outputs for overnight charge and battery balancing and waterproof so I can spill beer on it)
And I have been looking at cables again! 8 AWG Gauge is 10mm square. They are only good for about 50- amps. How do I know? Because using my bench power supply and just charging batteries down 2 metres on them (2x 1 meter) I lose a full volt. And they het very warm/hot at 40 amps. The 6mm ones as fitted to a stock F55 powerchair start to smoke at 40 amps continuous charge for 3 to 4 mins... And show about a volt and a half loss. I have to turn down the power as they look likely to melt.
So it seems 100 (8 gauge) is too small. I think you were using smaller still 10 gauge if I remember correctly?
We need 48 volt systems. Its getting silly.
With 160 amps on your DX system you should theoretically be melting those stock cables? No wonder they have a short boost time and rapid current foldback on powerchairs is there!
