The whole point of me buying this wheelchair was so that I could keep it for best and not take it to all the lakes and ponds that I visit when I go fishing. My current wheelchair which is the Corpus 500 would have been assigned to not only way backup wheelchair, but my fishing wheelchair as well. There's no point in me spending 18 K if I can only use one of the wheelchairs in my van.
Just get a used or cloned ezelock... http://www.ezlock.net/
Then add a simple bolt to any chair.
Ironside wrote:If something happened whilst you were driving in your van in one of these hybrid chairs then you wouldn't have a leg to stand on in court if you tried to sue the manufacturer of the wheelchair. In fact, if the wheelchair failed then I would bet the onus would lie with you for using a mishmash of different wheelchairs.
Ironside wrote:I don't know how you can possibly know that your wheelchair outperforms my current Permobil in every way, all you do is come across as being a tad arrogant. I'm very happy with my Permobil Corpus 500, it served me well for seven years. I used it every single day since 2011 apart from a couple of times when I've had problems. But I very much doubt there are many people out there who don't experience problems with a wheelchair at some time.
You are obviously in the very lucky position where you have the knowledge and specific skills to make a bespoke wheelchair that suits your needs. Most of us have to take what is available off-the-shelf.
All of these different makes of wheelchairs have been crash tested and the manufacturer will not sell you anything that has not been crash tested. It's all very well taking the wheels from one make a wheelchair, the seat from another, the backrest from a different type and then sticking them all together to make a hybrid, that wheelchair will not have been crash tested. I guess you would have to obtain the parts yourself and put them together at home. Again, if you are able to do this then that's all very fine, but I don't know anybody who could take part from different wheelchairs and then put them all together so it works properly.
Sounds to me like your annoyed that Permobil won't do what you want, hence it's a bad idea to get locked into a proprietary system. But It's your choice!
Burgerman wrote:Well one of my chairs does 16mph, has 45 to 50 miles range, has 6 inch wide tyres that work on the beach or pavement that are tubeless and kevlar reinforced. It uses a 150A roboteq controller at 45V, and is shorter than your permobil. And around 70kg lighter! So I absolutely know that that will out perform it! http://www.wheelchairdriver.com/BM%20MK ... lchair.pdf
Burgerman wrote:Thats why all my chairs just use a simple 16mm bolt as used on tow balls on the back of a car. Its easy then to make any chair fit.
Heres your problem https://permobilus.com/permlock-discontinuation/
Permobil Inc. is phasing out the Permolock C and Permolock C3 from our product offering. Starting March 1, 2015,
those webpages give 2015 as their update status.Permolocks are still listed on the Dutch and UK Permobil websites.
Permobil © 2015. All rights reserved
Users browsing this forum: No registered users and 36 guests
