Looks like the max is 150a per channel vs the 100a per motor from the OEM module?
150 "cont" or 250 amps peak, or 500 peak total. Limited in software to whatever you choose.
Yes, and when you also add lithiums, and almost double the voltage (it errors at 55 volts) you can go double the speed too. More importantly you can use RC and PC integration, free programming and datalogging software, as well as having more torque and power at higher speeds due to higher voltages.
There are downsides too. No motor compensation. Partly taken care off by the increased voltage and "power" limit in software in my case, but may be an issue in 24v use. And less safety. If it goes wrong you go under a truck...
More info on it as used on my BM3 chair here:
http://www.wheelchairdriver.com/BM-MK3-roboteq.htm
