Updated:  28-Apr-09
Drive your Powerchair by Radio Control >
Ever wanted or needed to be able to drive a PowerChair around remotely without actually sitting in it?
I know I did, so I made an interface that connects easily to all of my various powerchairs (about 5 in various states of build/condition at the moment).  It just plugs into the cable that normally plugs into the "control pod" and away we go!  Below...  Movies at bottom of page.
It uses a Model Aircraft Radio Control Receiver (and Transmitter) that is 35mhz but importantly it is PCM.
Which stands for Pulse Code Modulation. That part is essential. Its the part that stops any interference, or loss of signal from destroying your powerchair or house... Or from running away into traffic for e.g. and causing an accident!  This PCM bit matters! Don't consider trying this unless you think that part through first!
PCM allows you to program the receiver to STOP the powerchair as soon as any signal loss or interference happens. Even if someone is on your "frequency" it just stops.
How exactly you connect it to a powerchair I will come to later.
Why do I need it? Well today for e.g. I got into my van and drove another powerchair in behind me to transfer to the workshop at the local college for some modifications. There's no way I can do that while already seated in another powerchair!  I used it first thing too to bring my powerchair to my bed from the other side of the room.
I use it maybe once a week now for ten years or so. I work on powerchairs and clean them by sitting in one and driving the other remotely to the garage, workshop, into the house, etc.
I am pretty good at it now, I can drive two at once accurately through doors and along the pavements and around the house. Its actually very easy and smooth.  That's the one I am sat in and the empty chair too!
The square expensive blue and black part is a Penny & Giles interface for connecting puff and sip controls and other switches and stuff to a power wheelchair. It also has an analogue input that is pretty useful for my purposes. It has a 3 volt "voltage swing" input. Actually it has two.  One for forwards and backwards, and one for left and right.
So that's easy! It has, in addition to the plus and minus 3v inputs a 12 volt supply! And obviously a zero volts too. You just need to make your two radio control channels channels "swing" above and below a reference point by 1.5v each way.
This is the Penny and Giles "Omni Plus" external input interface, sat on top of a box containing a PCM 35MHZ Radio Control Receiver, two tiny "speed controllers" normally used to drive two electric motors to give an analogue voltage output from the two channels. And a simple passive resister circuit limits this to the required swing. It works smoothly and very accurately and safely with all Pilot Plus and similar P and G control systems.
Now the 12v supply on the Omni Plus can be used to power the Radio Control Receiver as well as two small 1 amp "speed controllers" designed for electric flight.
We need these since the output from the receiver is a bit complex to work with as its a pulse width square wave thingy that's way beyond my meagre electronics skills to figure out.
These all live along with the Receiver, inside that black plastic box in the photo. They do much of the work for us and convert that complicated signal to a nice analogue voltage swing. It was meant to drive a small electric flight motor from zero revs to max revs.
My oscilloscope and volt meter actually tells me that its a chopped square wave with mid stick being 50 percent duty cycle high frequency voltage but for our purposes its just an analogy DC voltage!  It works like one.
Now the voltage swing is about 5v since that's the supply voltage to the receiver and the little speed controllers via a simple 3 pin fixed voltage regulator chip. Bur that's too much. We need a total of three and that's plus and minus 1.5 volts either side of our reference voltage.
Now that's easily solved just using a few passive components, like fixed and adjustable resistors.  If you can even do basic electronics that wont worry you. If it does then better find a man that can because you probably wont figure out any of this!
Then you feed that 2 channel + & - 1.5v signal into the Omni Plus (the blue thing with the screen!)
But an Omni Plus (or similar) is expensive. I use one because it makes it dead easy to drive many different powerchairs about even when they are not mine.
If you really want to, you can just add your 3 volt swing (x2) to the analogue joystick wires inside the normal powerchair joystick pod. The Joystick is an inductive device with an analogue voltage swing output. Just follow where it connects and check what's happening with your multi meter. In other words you can do this without using the Omni Plus device if you are brave!
My 20 year old PCM Radio Control Transmitter. Not just used for powerchairs!
Inside the box below:
In the box!  The black and yellow thing is a simple radio controlled "switch". It simply turns OFF the Omni Plus once its stashed in the van, bathroom etc.  For battery saving or safety reasons.  Available in various forms from any online robotics place.
The PCM Receiver on the right is a stock model plane one with a failsafe (stop!) on signal loss or interference.
The "circuit board" is just simple passive components, resistors, 20 turn 5k trim resistors, capacitors (noise prevention) and a 5v voltage regulator chip.  And 2 tiny 1 amp electric flight esc (electronic speed controllers).
 I now have a new JR 12X transmitter for powerchair duties...
Recently replaced with a new JR 12X ( an even safer more secure spread spectrum 2.4ghz transmitter below)
I now use this instead. With a matching receiver
This receiver is a BR6000 Spektrum, specifically designed and programmed for robotics with a superior instant fail safe. The main reason for the change to spread spectrum 2.4 gear.. The failsafe just works instantly. No long 1 second delay before it stops! One second doesn't sound much but its a long time if its inside a van or while wrecking your house!
See Movies  (Windows media files)   Warning... Turn the sound down as the program I use to convert the .mov files to .wmv ones somehow doubles the volume and turns up the high frequencies! It really sounds like every other powerchair.
Short movie In the kitchen
Long bigger joined movie All over the drive, hall, kitchen
In the garden Radio Controlled Powerchair
wheelchair driver in position
Wheelchair in place ready to drive medium | wheelchair in place ready to drive large
There is a thread on the message board about how to do this radio controlled powerchair interface here!
Driven into here for a photograph of my new, home built, powerchair by radio Control!
T-Rex 500 Helicopter! Fly one from your wheelchair! (hobbies)
Detailed powerchair only menu
