New chair!
Re: New chair!
Postby shirley_hkg » 05 Jun 2017, 04:01
Please help me watching over ebay for this baby.
Will do. There has been a couple over the years. But they went for too much.
Often for sale on german ebay
http://www.ebay.co.uk/itm/ELEKTRO-ROLLS ... 5b33f81d03
But wrong options...
Ha , this one doesn't look abused .
Yep, the German site has quite some high end chairs from time to time .
What price range were they bought ?
Re: New chair!
Postby Burgerman » 05 Jun 2017, 06:47
No idea.
Re: New chair!
Postby shirley_hkg » 05 Jun 2017, 07:06
Can it really hit 13kph ?
Re: New chair!
Postby Burgerman » 05 Jun 2017, 10:04
Never measured. Feels about right. Suspension controls pitching really well too.
Re: New chair!
Postby Burgerman » 05 Jun 2017, 10:22
Outdoors its OK but programming or steering is less direct than my non brushless chairs.
Still seems way too nose heavy indoors. And a little housework has its motors very hot which seems to trip something that suddenly means no torque at all. It then cannot manoever or turn... You are stuck! And then seems to pull a ton of power from the battery. I wonder if using stainless bolts in the motors wheel rim is affecting it somehow? Its also way less accurate and intuitive at low speeds indoors than I am used to.
Re: New chair!
Postby shirley_hkg » 05 Jun 2017, 13:45
Strange .
We used to run 20 -30 km , with carer and tons of stuff , that motors are warm to touch ; guess below 50 degree C . :?
With wider wheelbase , it actually makes it easier to turn , doesn't it ? ;)
Re: New chair!
Postby Burgerman » 05 Jun 2017, 13:50
Outdoors, no problem.
Re: New chair!
Postby Dan » 05 Jun 2017, 13:56
Perhaps reprogramming it is making the motors work too aggressively? When it cuts out does it come back to normal when it cools down? How long does it take?
It sounds like the contrast between it and your self made chairs is more than you thought it would be. Maybe with a few more hours in it it will start to feel better.
Dan
Re: New chair!
Postby Burgerman » 05 Jun 2017, 14:13
With turn acc at 70, (max it allows) and turn dec at 100, it still feels vague. Esp at low speeds. Harder to move about indoors compared to my other chairs. Its more like sailing a boat rather than using a mouse! When it stops working its like some switch gets flipped. And torque just stops. No rollback, just almost zero torque. It will not move. Once it begins you can forget it. Wait hours to cool motors. I think...
Dont get it. May speak to invacare/dynamic.
I wont be getting used to it. I will make it work properly, my way, or get rid of it! I cant cope with anything that cant be steered properly! If I cant tear about the house at speed in confidence it isn't me thats wrong!
Re: New chair!
Postby steves1977uk » 05 Jun 2017, 15:03
It seems strange to have a limit on the acceleration value, but I guess this is adequate for 99% of their userbase. Be interested to hear why Invacare/Dynamic imposed that limit.
Re: New chair!
Postby rover220 » 05 Jun 2017, 15:10
Tt powered chairs always drive in a woolly manor compared to a geared motor. Doesn't seem to matter how aggressively it is programmed.
Re: New chair!
Postby Burgerman » 05 Jun 2017, 15:45
Yes, I have driven older ones. But what causes the sudden lack of torque and inability to move? The motors start to feel hot, in even moderately difficult work. Like turning left right as you drive around a room or two. Seems to be worse when I turn the turn acc/dec up to a level that allows me to actually steer!
Re: New chair!
Postby Burgerman » 05 Jun 2017, 16:43
Must be something here that will allow me to fine tune!
Wont touch any of these till I speak to Dynamic or invacare. These are over and above OEM level. But theres one I really don't understand. Ambient temp? Theres no temp sensor in a wheel I think, so its case temperature of controller?
Re: New chair!
Postby Burgerman » 05 Jun 2017, 16:46
No-Boost Current Limit Value: 75 Amps
Default: 75 Amps Range: 64 - 255 Amps
No-Boost Current Limit - the Motor Current Limit applicable after the Boost period has expired.
Suspect setting this to 100A will cure a lot of the unpredictability...
And setting temp rollback higher...
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 01:40
WOW ! Bunch of settings . Is it OEM level ?
I think I am not up to this yet . :o
Re: New chair!
Postby Burgerman » 06 Jun 2017, 01:52
Thats way beyond oem! Oem is intended for pride/sunrise/factory use etc. This is beyond that/them. This is really for the likes of Dynamics Controls development guys. Allows you to change some really interesting things.
One bit you might find useful, is the section on BATTERY. Have a read! You can configure it for lithium if you want. As you roll the mouse over the field, and the figure, the explanation and help appears at the bottom. So its actually quite simple if you understand whats going on.
Re: New chair!
Postby Burgerman » 06 Jun 2017, 02:29
Shirley this may also interest you.
This is the settings for my 10kph 6mph Storm 3... And is only in OEM mode. The difference is that in OEM level you can see all the same settings, but cannot change them. They are greyed out. Most here are grey in OEM.
We can UN-grey them!
Now, the only difference in top speed between the 6, 10, and 13kph versions of brushless chairs appears to be the setting called: INPUT DEMAND SCALER. see below.
On my 8mph (13kph) version it is set to 100.
On my 6mph (10kph) version it is set to 78.
On the 4mph (6kph) versions presumably its set to a lower figure still.
So if your chair is slower than 8mph you can speed it up.
Also see the ACCEL STOP X and Y fields. These speed up the "stop" after you position a chair by an inch say. You let go and it stops faster. Also interesting to make it more easy to drive indoors... There are similar ones that do the opposite.
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 02:49
You mean your 10kph STORM 3 is leashed , and now you can unleashed it to 13kph ?
WOW . That really amaze me .
Your last point catches my attention too .
Here people using MK 6i models are complaining that their chairs stopped with a few more inches forward rolling , even when they release the stick at a crawling pace .
Seems this parameter can solve the problem , itsn't it ?
Re: New chair!
Postby Burgerman » 06 Jun 2017, 09:38
Yes. If set higher it stops fast, the last few inches. But less smooth. Read the info in the box at the bottom. Set to 100 it stops dead as you release stick last few inches. Very sharp!
But this software cant work on the older pre dx controller can it?
Speed. MAX motor rpm is the same 220 on every brushless motor. They reduce it from 8mph (220) for all slower 6, 10kph chairs with the DEMAND SCALER parameter. So you just set to 100%. All brushless chairs are then 8mph.
GB-DX. GB-DX-AS. GB-DX2. Only I think. Maybe I am wrong? Square bus connectors.
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 10:24
Where do you hook it up ? To pm direct , or via joystick ?
Re: New chair!
Postby Burgerman » 06 Jun 2017, 10:38
Joystick.
It needs either a DWIZ ADAPT for the newest fancy colour screen REM550 or just a cable with no electronics for the REM24 for eg. And serial port, or a USB serial port adapter. But it only works on modern DX bus systems I think.
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 10:44
BTW , battery guy replied that minimum order is 100 pieces from SINOPOLY .
How many 40152 can be fitted ? Those 400 new old stock we've bought are very healthy , and economical .
Re: New chair!
Postby Burgerman » 06 Jun 2017, 10:48
Not enough!
Re: New chair!
Postby steves1977uk » 06 Jun 2017, 12:38
shirley_hkg wrote: BTW , battery guy replied that minimum order is 100 pieces from SINOPOLY .
How much are the 40152's per cell Shirley? Was thinking of building a pack for my F55 chair and get rid of those Haze batteries.
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 13:51
£5 --£6
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 14:05
Burgerman wrote:Cool! Need 8 asap!
viewtopic.php?f=2&t=1813&start=2480
BM , you should give this 75Ah cells some thought again . Their IRs seems better than the brand new SINOPOLY 125AH .
Your box can fit 15 of them . Need 1 more . May be outside the box ? You will have 150AH then . 135AH @90% still .
Re: New chair!
Postby shirley_hkg » 06 Jun 2017, 15:04
Burgerman wrote:Must be something here that will allow me to fine tune!
OH MY GOD ! ! !
Re: New chair!
Postby Burgerman » 06 Jun 2017, 16:35
Yes...
But unfortunately even this software will not allow us to change from 220... Which is 8mph.
Re: New chair!
Postby steves1977uk » 06 Jun 2017, 21:08
shirley_hkg wrote:£5 --£6
That would buy me between 50-60 cells if I spent £300. Guess I'd have to buy the orange blocks and bussbars separately? Might be worth a gamble for a backup chair.
Re: New chair!
Postby shirley_hkg » 07 Jun 2017, 03:35
Holders are 5 pieces per £ , and the pure copper bus bars I used are available too . You can order the number of holes per bar .
Users browsing this forum: acid_coke, Bing [Bot], emilevirus, JMGarage, sergey0, shirley_hkg and 171 guests
