which chair is best or better.
Re: which chair is best or better.
Postby Burgerman » 29 Jan 2016, 10:50
Type B or , Type A ?
will I need other cables?
For the 2nd time.
B and no.
Postby carlo67 » 29 Jan 2016, 11:20
if I buy this http://www.hidrex.de/reha/programmier-d ... t-typb-oem and I use the n-net OEM software?
carlo67
Postby Burgerman » 29 Jan 2016, 11:26
YES!!!
It says:
Programmier-Dongle R-Net OEM, Typ B
Postby carlo67 » 13 Feb 2016, 15:35
I can't find anyone to sell the dongle R-Net OEM to me
anybody help please
carlo67
Postby steves1977uk » 13 Feb 2016, 16:16
Yes they are hard to get hold of, unless you're good at convincing them :mrgreen: Here's a few tips:-
1. Say the chair drives poorly like dodgems (bumper cars)
2. Say its for sport use and you need a responsive chair without any programmed delays
3. Say you rebuild your chair(s) and need access to set the motor compensation correctly to match the new motors you're fitting (eg. going from 2-pole to 4-pole)
These are the top 3 I would use. Others may have different suggestions.
Postby carlo67 » 20 Mar 2016, 09:18
hi
I have some of good and bad news.
next Wednesday I will getting my new chair wow but I don't have the dongle R-Net OEM.
can anyone help me to find the dongle R-Net OEM please.
carlo67
Postby steves1977uk » 20 Mar 2016, 11:28
carl, you gotta fight for it yourself. it's no good keep asking where to get an OEM programmer from, you gotta work that out on your own like many of us had to.
Postby Burgerman » 20 Mar 2016, 11:53
If all else fails, get them to enable On Board Programming. It does quite a bit, and no programmer needed. It may be enough for you.
Postby carlo67 » 20 Mar 2016, 22:47
Burgerman wrote:If all else fails, get them to enable On Board Programming. It does quite a bit, and no programmer needed. It may be enough for you.
I would like to change my profiles and settings like:
Forward Acceleration
Reverse Deceleration
Turn Acceleration
Turn Deceleration
Forward Speed
Reverse Speed.
Turning Speed
can I do that?
carlo67
Postby expresso » 20 Mar 2016, 23:49
yes i believe so - those or basic settings and i am almost 99% sure they can be adjusted if at least onboard programming is enabled from the joystick
and it actually can be already - you need to try to do it on your joystick - i dont remember the correct procedure to do that - i know its in the manual somewhere
and if you happen to find an Rnet dongle - it dosnt have to be the OEM version to make those changes - if you can get the Dealer version - you should be fine -
search on Ebay - they show up every so often -
Postby Burgerman » 21 Mar 2016, 00:25
Turn Acceleration
Turn Deceleration
Forward Speed
Reverse Speed.
Turning Speed
can I do that?
You missed:
MINIMUM Turn Acceleration Set to 100
MINIMUM Turn Deceleration Set to 100
MINIMUM Turning Speed Set to a low figure like 25
can I do that?
YES
Postby carlo67 » 21 Mar 2016, 01:05
carlo67
Postby Burgerman » 21 Mar 2016, 02:20
No.
Postby expresso » 21 Mar 2016, 02:53
thats not the dongle for the Rnet joystick ?
isnt that what he is looking for ?
Postby carlo67 » 21 Mar 2016, 03:13
Burgerman wrote:No.
is this enough to change my settings and profiles ? http://www.ebay.com/itm/PG-DRIVES-PERMO ... SwHQ9WZxMs
Turn Acceleration
Turn Deceleration
Forward Speed
Reverse Speed.
Turning Speed
can I do that?
carlo67
Postby expresso » 21 Mar 2016, 03:22
believe or not for that price - just 30 dollars more - you can buy the dongle brand new - dealer version -
i rather do that - if this is the correct item you need for your chair - i dont know what you have etc, - BM knows best -
unless thats a OEM version - but what you want to do - just those basic items to change - dealer is fine
Can you get the dealer or vendor to unlock the joystick for OBP ? if you can get that done - for free it should be - you wont need anything else - you can use your joystick to change those settings -
http://marketing.sunrisemedical.com/Tec ... Manual.pdf
page 28 i think - it explains the steps to take - you can try it and see if it works for you
Postby Burgerman » 21 Mar 2016, 08:17
Find someone that has an OEM verssion. And use that to enable OBP and then you have the dealer version built in for free...
Postby carlo67 » 21 Mar 2016, 10:32
Burgerman wrote:Find someone that has an OEM verssion. And use that to enable OBP and then you have the dealer version built in for free...
what lolol I can't understand what you try to saying.
I have already the OEM verssion software
carlo67
Postby CPguy » 21 Mar 2016, 10:58
@carlo67: A dongle is about access (https://en.wikipedia.org/wiki/Software_ ... ion_dongle).
To change or make changes in the wheelchair software you need:
1.) A wheelchair + a dongle (access can vary hence dealer or OEM Level) + the programmimg software itsself.
2.) A wheelchair + a programming tool (i.e. a "handheld programmer")
3.) A wheelchair + a contoller that allows changes directly (i.e. "on board programmging"). This is normally a check box which can be activated by using 2.) or.3.) depending on manufacturer and / or access Level granted by the dongle.
On board programming normally allows access to the same features as a dealer level dongle.
Simple.
My rides:
2 Progeo YOGA (for traveling)
CPguy
Postby carlo67 » 21 Mar 2016, 11:26
ok than
how to get across to the On board programming ?
carlo67
Postby Burgerman » 21 Mar 2016, 11:55
Ask for it to be enabled.
Or find any user or tech with a oem programmer to enable it.
Postby carlo67 » 21 Mar 2016, 12:07
Burgerman wrote:Ask for it to be enabled.
ok I will try but I don't like my chances lol
carlo67
Postby steves1977uk » 21 Mar 2016, 12:09
One word of warning, my friend Dave (dgt) accidently locked himself out of OBP which he had to come and visit me again so I could re-enable it again with my OEM dongle.
So be careful which settings you change!
Postby Burgerman » 21 Mar 2016, 12:14
Also when you enable it, check to see any walls are also removed. Or they mal limit your choices.
Postby carlo67 » 22 Mar 2016, 07:26
Hi Carlo,
there is no “on-board” programming.
I’m afraid that you are NOT able to change any of those programs yourself.
Cheers,
Phil
carlo67
Postby carlo67 » 22 Mar 2016, 10:59
carlo67
Postby Burgerman » 22 Mar 2016, 11:43
Hi Carlo,
Cheers,
Phil
Wrong!
We are talking about Rnet right?
It can be ORDERED with this enabled.
It can be enabled subsequently by anyone with OEM level access. Both with or without a password.
The mistake you are making is that you are talking to an idiot.
http://www.wheelchairdriver.com/pdf-files/r-net.pdf read here. Page 65 tells you what it does compared to OEM access.
Tell "phil" you will get the chair from somewhere else that has a clue.
Postby steves1977uk » 22 Mar 2016, 13:12
Not if it has the standard LED controller, then OBP is a no go. Which joystick type does carls chair come with?
Postby dgt » 22 Mar 2016, 14:19
As Steve said; I managed to shut down the OBP on my Alex by mistake. IT IS VERY EASY TO DO! BE WARNED.
I did it by trying to 'back out' of OBP with an incorrect value entered by myself. As soon as I closed down OBP it flashed up a message on the screen that incorrect data had been entered. With that cleared, I could no longer access OBP and as Steve said it meant another trip to see him (which I didn't mind because he is a true gent!). :D
Dave
dgt
Postby steves1977uk » 22 Mar 2016, 14:41
It was no problem Dave, I like to be able to help people :)
Users browsing this forum: Burgerman, emilevirus, JMGarage, Yennek, yeshelp and 173 guests
