Burgerman wrote:Cell 8 group, looks like theres a cable or cell or bolt problem somewhere. Why is discharge in 3 parts?
And on charge it looks inconsistent. Are you sure all the bolts are tight? The green line looks like you get with long cables or bad connections, thin charge wires. Or a pack split in two with extra connections.
Do another discharge/charge and watch. Lines should all be together or extremely close.
Burgerman wrote:What about main charge cables? Balance start should be set to 3.500v not lower or set to balance at CV only.. Balance while discharge should be off.
lets say - i had a GOOD BMS on this pack - would it have helped at all somehow ?
i am starting to see many many more lithium batteries now that are drop in models - of course with a BMS - and double the cost of what we can do it for ourselves - at some point - someone has to make a GOOD SOLID BMS that would do its job correctly ?
shirley_hkg wrote: Do you have 2 X 115mm headroom for these 55Ah cells ?
Around @ £15.00![]()
OH -
I put it all back together and then connected to the PL 8 - and monitor - - that screen shot was a monitor before i did anything at all -
now i am discharging it - i may have a chance that it will fix itself - ?
