Re: PGDT interface update
Postby LROBBINS » 19 Apr 2013, 19:04
And if the MCU in the joystick requires both outputs to match, the error code if you hook up just one voltage divider might well be "out of calibration". Ciao, Lenny
Postby lordk » 22 Apr 2013, 13:36
Yes, output 1 , output2 and center are all shortened. Iam missing something here.
lordk
Postby woodygb » 22 Apr 2013, 14:00
lordk wrote:Yes, output 1 , output2 and center are all shortened. Iam missing something here.
Ummm ..don't know as the statement makes little sense.
From the joystick pdf
pins 2&7 left/right and pins 4&5 fore/aft should output the "same" voltage...
Therefore
When you replace the joystick with some other interface device you must then emulate ALL the original joystick voltages.
Postby lordk » 22 Apr 2013, 14:39
woodygb wrote:When you replace the joystick with some other interface device you must then emulate ALL the original joystick voltages.
Yes, but at startup all pins have the same voltage, I just want to do that at first step ,
AxisX1, AxisX2, AxisY1, AxisY2 and center have the same voltage otherwise flashing leds occur.
lordk
Postby woodygb » 22 Apr 2013, 14:45
Ah! ..yes all @ 2.5v
Postby lordk » 22 Apr 2013, 15:29
I was having a bad connection in my breadboard. My bad.
2.4V is the winner! :)
I have 2 weeks before my DACs arrive. I will use potenciometers or R-2R DAC meanwhile.
thx for your help.
lordk
Postby dude8604 » 30 Apr 2013, 07:51
I've been through this thread and I'm still confused what the consensus is on what the correct pins and voltages are. I have a PGDT Pilot+ controller. What is the right way to do this?
Also, how do you get the PGDT programming software?
Thanks.
dude8604
Postby woodygb » 30 Apr 2013, 08:42
I haven't managed to find a lead ( make / model ) that will ALWAYS do the job.
viewtopic.php?f=2&t=2111&start=220#p39061
I actually bought a VSI and have had success using the diode technique on SOME of my KPG type leads ...but NOT the FTDI which only works on the PILOT+.
Postby dude8604 » 19 May 2013, 06:49
I think I might be able to make that work, I got a different USB to TTL converter - not based on FTDI, but I have Pilot+ anyway. What I need to figure out though is how to get the Pilot+ programming software. Would anyone be able to give me that? Or if not, where could I buy it? Thanks.
dude8604
Postby lordk » 01 Jul 2013, 12:27
lordk
Postby Lord Chatterley » 03 Aug 2013, 11:09
woodygb wrote:
rune wrote:I'm not happy with the programming cable thing....
I bought the radioarena cable but i'm having even less sucess with this one than my previous cable; I think it's faulty.
In windows, on two separate machines, in win2k and XP the driver will not start correctly (error 10). I've tried different driver versions, etc but to no avail.
I have four or five other USB cables with use the PL2303 driver and on each one of these, they show up and work with no problem.
I'm going to have to contact radioarena and see if I can sort this out. The only trouble is, i've already chopped the modular plug on the end and soldered on an XLR :-(
I'm confused as to why you ignored this pic ...or did you not see it?
And how you came up with your own colour connection version.
The one I had worked out to white common, black and red TX and RX.
Woody, in some of the cables pictured above - red is white and white is red! :roll:
LC
Lord Chatterley
Postby woodygb » 03 Aug 2013, 12:24
There appears to be NO SET colour for the wires ...the wire colours seem to vary depending on the whim of the Chinese supplier of the cable.
Popping the case is the only way to be absolutely sure.
Here's an updated pic ...AND ... I have yet to find any radio programming cable ( KPG Baofeng etc ) that will not work with the addition of the diode.
Postby woodygb » 03 Aug 2013, 12:40
of the case type shown in the above picture.
BLACK has ..so far ..in ALL the various USB Programming cables ...that I've opened the case on ...been GND.
If there is just 3 wires and one is Black then we can be fairly confident that it is GND and it should be just a case of trying the diode in each of the other colours to get a working lead / COMS ACTIVE.
Postby Lord Chatterley » 05 Aug 2013, 01:18
Thanks, Woody. It was very good of you to spend so much time figuring all this out.
LC
Lord Chatterley
Postby woodygb » 05 Aug 2013, 08:28
If you don't want to pop the USB casing and have a continuity tester you can check which wire is GND by probing between the metal of the USB casing and the various coloured wires.
Postby PowerHungry » 11 Aug 2013, 02:12
Hi woody
I just got a qtronix/p&g 100 amp module off ebay and need the cable you made and I was wondering if you would sell me a cable please as I am rubbish with diy electrical stuff?
PH
PowerHungry
Postby nlt99 » 17 Aug 2013, 02:23
Hi all.....
I am a bit confused....... I have seen this wiring diagram for the Radio Arena UC01KM cable with the green and white wires connected to pin-3 of the neutrik plug. I have also seen a wiring diagram somewhere in these forums where there is a diode wired into the circuit, connecting the Tx and Rx lines I believe.
I am trying to program a VR2 controller with a laptop running XP...... which diagram should I use please?
Thank you! Nick
nlt99
Postby nlt99 » 17 Aug 2013, 02:50
Ooops....... sorry...... I didn't realize I wasn't at the end of this thread when I wrote the last post. I see here the diagram with the diode inserted....... is that what I should use with my Radio Arena cable for programming the VR2 controller?
Also, in regard to a previous post about a Radio Arena cable not working and posting an Error-10 msg, I saw a message on a Prolific website warning that there were counterfit PL2303 chips coming out of China marked exactly the same as the genuine chips from Prolific..... you can't tell them apart. The counterfit ones fail with an Error-10 msg according to Prolific. They only recommend a couple of cable manufacturers to be sure of getting genuine chips. Wonder if that could be the problem with the cable you got recently...........
Nick
nlt99
Postby woodygb » 18 Aug 2013, 22:57
PowerHungry wrote:Hi woody
PH
Not sure how I missed your request ... I can if required supply a USB based cable.
Postby PowerHungry » 19 Aug 2013, 20:42
PH
Hi
Thanks for getting back to me.
USB is fine. Will this cable be able to program pilot plus module? What software would I need?
PH
PowerHungry
Postby woodygb » 19 Aug 2013, 20:59
There is a link for uploaded software here and it will program the Pilot+...
viewtopic.php?f=2&t=3461
Postby PowerHungry » 20 Aug 2013, 01:41
woodygb wrote:There is a link for uploaded software here and it will program the Pilot+...
Thanks for the link. Appreciate it. How much would you sell the cable for? :D
PH
PowerHungry
Postby woodygb » 20 Aug 2013, 07:52
£20 plus postage ...I'll need to order in another couple of leads to modify.
Postby PowerHungry » 20 Aug 2013, 13:17
woodygb wrote:£20 plus postage ...I'll need to order in another couple of leads to modify.
Deal! Let me know when you are ready....
PH
PowerHungry
Postby woodygb » 21 Aug 2013, 20:29
Ready ..P.M. me your details.
Postby PowerHungry » 21 Aug 2013, 21:23
woodygb wrote:Ready ..P.M. me your details.
details sent
PowerHungry
Postby bgmen » 25 Sep 2013, 18:34
How to make Programming Cable for Wheelchair pilot plus.
bgmen
Postby woodygb » 25 Sep 2013, 19:01
Postby woodygb » 25 Sep 2013, 19:09
Take a lead like this .. http://www.ebay.co.uk/itm/USB-Programmi ... 565bb777a0 .
Buy an XLR/Neutrik plug and a 1N4148 Diode
Cut the 2 pin plug off the lead ... and wire according to the diagram.
Postby bgmen » 25 Sep 2013, 19:22
I tried but it is not the computer does not recognize it
woodygb wrote:There appears to be NO SET colour for the wires ...the wire colours seem to vary depending on the whim of the Chinese supplier of the cable.
bgmen
Users browsing this forum: acid_coke, emilevirus, jefferso, jehan, shirley_hkg and 523 guests
