Still seeing if I can use the existing digipot to output the 6v centre and 1.2v-1.3v swing... the spec sheet suggests that I may not be able to use it.
Yes...I did finally manage ...at least according to my cheap multi meter ... a 6v centre and 1.2v swing .Woody, were you able to make the MCP42X1 work and did you use a 6 v center with a 1.2 v swing?
...I've programmed the Arduino to recognise a signal of 1 or less ( null ) to be a failsafe condition...removing a signal wire from the receiver certainly makes the Arduino failsafe..but haven't had a receiver to test that it also works in actuality.Removes servo output pulses to all channels except the throttle channel
during failsafe.
woodygb wrote:I have 40 steps each way on my trim ..which equals 100 of the signal range 1900 - 1500 - 1100 ..so from 1400 - 1600 ...and the LED's were lighting up after 4 -5 clicks.
The digipot has 128 steps in each direction and your presently losing ...due to the way I'm presently programming my deadband ..the first 6 steps = 0.06v.
I need some sort of deadband ..but it's an easy fix to make the deadband = 1 step ..
The LED's may however blink on/off @ neutral as the signal ...( at least on mine ) ..drifts a little.
Users browsing this forum: LROBBINS and 111 guests
