Just a note to say that despite the version saying Dealer it is ... or appears now to be ... Access level C = Manufacturer level.
For example, "Front Drive Rate", which is critical for me because the default is 0 and I need it at 80.
Your solution is Engineering level, not OEM,
...The NEWVSI is the only one that presented any problem and required this work around solution.The only problem is that anyone with fences set up, and there's a good few like this (the ABS settings) will not be able to get past them.
...Ummmm would you check that for me ...as my installed v14.4.3 hasn't got a print option.The latest version of Mobility PC Programmer (Manufacturer Service/ Standard version). It can't change anything, but it can print out ALL configuration details
At top speed, I can still move the joystick some without it resulting in a change of direction. (But at least now I can do top speed without being in fear of running off the footpath, or driving someone over! Which most definitely was NOT the case before I gave up on dealers and reprogrammed it myself, in accordance with Burgerman's advice!)
Burgerman wrote:At top speed, I can still move the joystick some without it resulting in a change of direction. (But at least now I can do top speed without being in fear of running off the footpath, or driving someone over! Which most definitely was NOT the case before I gave up on dealers and reprogrammed it myself, in accordance with Burgerman's advice!)
I don't KNOW what it does. But front drive is an unstable configuration. The faster you go the worse it gets. If the chair was fast enough there is no controller or system, even closed loop ones, that can stop it spinning around completely and facing backwards. Steering at all becomes more and more over controlled as speed goes up. So as speed increases there is a 'need' for less and less "control" ... Because you cant HAVE control with front drive at speed.
Users browsing this forum: Bing [Bot], duke1, LROBBINS, Superchunk and 324 guests
