falco peregrinus wrote:My wife has a Q6 Edge. I hate it. The original programming is as bad as it comes, and the damned thing gets hung up between the front and rear castors all the time, with the drive wheels not touching the ground so have no traction. The Quantum controller has a proprietary programming socket, which causes problems when you try and reprogram it, and the chair is BIG. She likes it, but I hate it. I don't recommend it.
Falco.
I find that the programming setup is just fine as far as steering and 'go'.
Burgerman wrote:I find that the programming setup is just fine as far as steering and 'go'.
Seriously? I think you need to try a chair where all the low speed turn acc and dec as well as high speed turn acc and dec has been set to 100. OFF. And the high and low speed turn rate reduced to the point where it feels easily controllable. Because this is a world away from what you are experiencing!
If they did, then they missed doing my wife's Q6 Edge. It is the worst chair I have ever driven! Absolutely uncontrollable
So if you guys have Q6s that do that, they don't need to.
So buying pride stuff leaves you at the mercy of whatever some guy thinks is a good idea. So while some are better than others all are still a bit crap!
Users browsing this forum: No registered users and 206 guests
