hotwheels_75 wrote:I finally got some of my wiring figure out, isolated the Seat tilt power harness & removed all onboard charger stuff.
Can anyone recommend a good weatherproof quick connect three pin connecter for the tilt harness?
I also need to shorten most of my cables, they're all extra long. Is there an easy replacement for the 4 wire motor connectors?
I'm not sure how the box you pictured works, or hooks up... What I had on my Redman project chair was a P&G ALM (Actuator / Lights Module) module that had a Redel cable and plug just like the cable that went to the joystick pod, and which plugged into the second Redel socket on the power module... The module I have could control at least 4 actuators (tilt, recline, and each leg) plus head / tail lights and turn signals. (It was intended for use with a 7-button Joystick pod) The module had sensors in it to detect what hardware was actually present and only gave the options to operate the stuff that was actually connected...
The wiring was pretty simple, just two wires to each actuator and set of lights....
My first choice for any sort of moderate power application, such as an actuator, are the small 15/30/45A Anderson Power-Poles.... They aren't weatherproof as such, but are OK, and you will see a LOT of them used on power chairs by manufacturers... I think they are an excellent choice for anything that takes more than an Amp or two...
Not sure about the Pilot + motor and battery connectors, they do exist and I've seen part numbers mentioned in the past, but I don't have them handy at the moment...
