I had this Digimess PSU repaired before when the PL8 killed it. Think I mentioned this before about 6 years ago.
Didn't realize there are 38120mm cells also
Burgerman wrote:Buy metric allen screws. Stainless. Dont use the split shake proof washers only flat washers.
ICEUK wrote:Biggest problem with doing a lithium battery conversion is you forget when you last charged your pack,![]()
Burgerman wrote:They come loose as the battery flexes and bets banged around. And you cant get them reliably at the correct tightness. They are cheaply made. Allen bolts are better. They need
to be surgically clean connections and threads locked. Or you will get issues.
Arima wrote:I think this is the first time I've seen mention of a valve. One end of the cell looks like it has vent holes...so that might be the one. 10mm bolts look like they should be fine. Great idea about making a tap! Put a little oil on it and worked a bolt in going back and forth without any trouble. Dirty connections cause more resistance correct?
Users browsing this forum: LROBBINS and 487 guests
