Use the ZXD. Set amp to 5A.
Charge one cell at a time , till 3.0V, and next.
PL8 should work too , if you reset the detect volt low enough.
again! (just joking
Burgerman wrote:If its down to few volts - complete pack, you are wasting your time really.
Use the ZXD to charge the pack. Set amp to 3A.
Monitor the volts with PL8 , and note that none of the volts go negative.
(steal it)Scooterman wrote:FishinJunkie
Hi, I'm guessing 207mm is the height? 8 cells would fit in my scooter. It has 2 battery trays either side of the seat post, so 4 cells in each tray.
Battery Size:
174*53*207mm
Is this how they arrived? And the M6 studs are actually welded into the terminals? They look good and I like the way they protected the threads with what looks like a piece of heat shrink sleeving.
NB: If I can't rescue my existing pack then I'll email the lady for a GBP price.
Burgerman wrote:That looks promising. Cant really have been at 1v?
fishinjunky wrote:
Yea they came with the studs welded. And packed well.
The 207mm is without studs I think 224mm with studs but ask the lady to be sure
They came with heat shrink on the terminals
I'm happy with them
I'm happy with them
Hi FJ, I emailed the lady and she gave me good price and sent this. Looking at the photo some look to have welded studs and some don’t. Are yours in this photo?
fishinjunky wrote:I think they will weld m6 studs on the any of their cells if you specify that's what you want
Users browsing this forum: No registered users and 473 guests
