Looking to build parts (handles, knobs and mounts for electronic projects).
I have never even touched one before. Any suggestions for a newbie are sincerely appreciated.
http://www.monoprice.com/product?p_id=13860
Burgerman wrote:Fine detail is good. But the thing stopping me is this. Software... I learned some autocad once. What a complete bitch that is. Dont want to go there! What is easy, intuitive, and will work with this printer?
Burgerman wrote:You actually pay for software?Torents...
OK will download those and take a look. The bigbox one looks pretty good to me but I dont know what I am talking about
Burgerman wrote:Buy cheap. Pay twice.
Buy what you really want/need, buy once. Much cheaper.
Do that with everything in life and you end up a lot better off and with all the best tools. But I downloaded the software and it looks beyond me...
Burgerman wrote:Downloaded. Doesent look mucvh easier! Will watch tutorials...
Irving wrote:Choosing a 3D printer is a mine field. I've been using an ultimaker 2+ in the lab and its pretty good, but not perfect. Limited to 1 extruder and as standard doesn't get hot enough to do nylon or carbon fibre (tho it could do some brands of said filaments). for what I need PLA/ABS aren't up to the job, I need a hi-tensile nylon (planetary gear trains).
So my must have list:
- heated & self levelling bed
- 200mm x * 150mm y * 150mm z print volume (z (height) requirement is negotiable)
- enclosed printing space for temperature (and noise) control
- dual head/dual feed (can get triples now on some 3D printers)
- higher temperature (260 - 300degC) extruder capability for nylon
- exchangeable/replaceable nozzles in at least 3 sizes
- open software
CEL Robox 3D looks good but needs extruder upgrade which just tips it over my 1000GBP budget. More research to be done!
terry2 wrote:...Looks like people are using nylon with your printer https://ultimaker.com/en/community/1610 ... ltimaker-2
Have a look at https://bigbox-3d.com/ it can go to 400c
Burgerman wrote:Speed and also accuracy, strength of parts, difficulty in programming or designing, noise, power consumption, expense of materials, and what to use it for!
The general concensus was that THEY are hobbies -- for folks who want to spend their time tinkering with the printer instead of the thing that is being printed!
Burgerman wrote:The general concensus was that THEY are hobbies -- for folks who want to spend their time tinkering with the printer instead of the thing that is being printed!
And right now, thats the state of play. They are impractical as tools.
Burgerman wrote:You can print carbon fibre?
How does that work?
ex-Gooserider wrote:Burgerman wrote:You can print carbon fibre?
How does that work?
Basically by having a nozzle that feeds in the filament as you are printing the part, with the result that the fiber is embedded into it. Requires extra planning to arrange the way the fiber gets laid down...
The problem is that since the part can only have fiber put in as it is printing each layer, you get great strength in the X-Y plane, but still have layers that are readily separated on the Z plane. Thus you can only make parts that are structurally robust in two dimensions, which may not be enough...
(Look for Mark Forge printers)
Users browsing this forum: Yennek and 236 guests
