geordie graham wrote:Having had a test drive on a Frontier V6 on rough muddy ground I can say that it is a very good comfortable outdoor chair.
Burgerman wrote:I agree its good outdoors. Indoors its too high, long, and wide for me.
Burgerman wrote:Not sure about the battery compartment size, but it uses small batteries, and has a budget VR2 controller (low amps) etc. And if you take it on the beach/snow/mud it will sink...
R-net is available, as you have, as an option but not sure the motors are capable of taking advantage of the extra amps. If they were then its a bit daft using them on the VR2 model. Could be wrong here. But mid drive chairs upset me anyway! Its a triumph of extra casters, marketing, and dubious engineering over physics. But everyone is different!.
Maybe they will come up with a lightweight long distance all terrain chair that also manoeverable in confined spaces. It's definately worth a trial I absolutely love Mine though
Burgerman wrote:The thing with lithiums is you can make them many shapes or sizes, so yes.
Burgerman wrote:That depends on cell type, bms used if any, charging solutions, capacity required etc.
With lithiums the best way to do things costs. The easy way, is simple and cheap, but often results in no real gain over lead, and shortened battery life.
See http://www.evassemble.com for eg. Look at high rate cells like the 10, 12, 15Ah lithium cells as I use in my own chair here: http://www.wheelchairdriver.com/BM-MK3- ... rchair.htm
Burgerman wrote:Listens???
Can hear the tin opener opening that can.
Burgerman wrote:It is. But in reality, you need better more powerful motors, more powerful controller, all by 25 percent. This means you also need 25 percent better (bigger heavier) batteries that do not fit in the space, to make this work as well as a 6mph chair. Or range and torque (one or the other or both) will suffer.
Users browsing this forum: No registered users and 89 guests
