by ex-Gooserider » 21 May 2012, 02:46
Never heard anything particularly bad about the Pilot+ series of joysticks and controllers, other than the lack of power problem that all chair controllers have. There is no such thing as getting a truly accurate battery indicator with lead acid batteries, the nature of their chemistry makes it impossible, but the Pilot+ indicator is no worse than anyone else's... If you do have a Pilot+ joystick pod, your controller will also be Pilot+, as the electronics modules on a chair are a system, and if designed to work together all will be from the same controller "family" - there is no "mix & match" compatibility....
The motors are mostly independent of the electronics, so I don't know what the brand of motors will be, but they are going to be geared, as the only folks that ever did gearless-brushless motors as far as I know is Invacare, and I believe they have discontinued them.
The biggest variable in geared / brushed motors, is whether the motors are two pole, or four pole. You can tell which you have on most motors by looking at the side of the motor on the end opposite the gearbox. You will see a band of metal as part of the motor body, with either two or four large plastic screw heads on it. These are your brush holders, and the number of holders is the number of poles the motor has. Four poles are better than two, but either type will do a reasonable job for most users.
Otherwise, appearance doesn't mean a lot. Other than mounting hardware, the insides of the gear motors are fairly similar, except for the gear ratios in the box, which isn't something you can see from the outside.
Hope this helps,
