Burgerman wrote:Definitely not!
That will CAUSE your problem.
Dont use their presets.
Use mine.. Several reasons.
Set to 3.5V balance start or set to balance at CV only. Then charge fully, first, then discharge by 50Ah. Then recharge and post graph.
Burgerman wrote:Glue, screws???
Test first, see if group 1 has less capacity.
Burgerman wrote:For 84Ah 8S LiFePO4
This is set to suit your pack.
It is 20A charge, 3.5v balance start, 500th termination, no +8mv at CV, wide cell balance limits, and voltage and time limits, etc and a bunch of other hidden settings changed to suit. Remove.zip
Charge, discharge 40 to 50Ah , then recharge and lets see the curves.
Burgerman wrote:Are these on group 1? If not what do they have to do with anything?
You need only check if 14 bolts on group 1 are tight.
Burgerman wrote:https://www.amazon.com/gp/product/B01H6QFSUC?ref%5F=cm%5Fwl%5Fhuc%5Fitem&pldnSite=1
YES...
Burgerman wrote:Charge, discharge 40 to 50Ah , then recharge and lets see the curves.
Burgerman wrote:Make sure discharge balance is OFF!
As it is on my profile.
The internal discharge is limited to 10A or 100W, whichever occurs first.
Burgerman wrote:There are ways to discharge at 30 to 40 amps.
Burgerman wrote:PL8 is powered by the power supply.
The load dump is ALSO powered by the power supply. Its connected in parallel.
When you turn on the power supply the load gets hot...
I set my power supply to 25V. I set my PL8 to use a 24V Optima battery as a power supply, and enable regenerative discharge. I set it to a max 15.6V and a max of 35A into the "battery".
In the regen discharge setting for the lithium pack I choose max. Or something higher than I expect the charger will be limited to on the regen Amp setting.
Then choose discharge, regen, and go! As the Amps ramp up, the regenerative power pushes the dump voltage above the power supply voltage and so the power supply now contributes zero Amps. And there is a 35A 30 volt regen current. If you choose low amps, the power supply will still contribute. And waste power. You have to feed more amps in than the power supply is doing before you press go. So if you only want to discharge at 20A then set power supply to 12V. And then it will be only pulling about 15 amps. Then the 20A regen will be enough. You need to understand whats going on its too hard to explain.
Users browsing this forum: LROBBINS and 113 guests
