shirley_hkg wrote: We can't expect BM's results in our packs , as he spent months in measuring capacity , self discharge rate , ir ; and even them through out his pack . His is safe to discharge to its last drops of juice . Down as 20V .
Instead , you and I built ours blind folded . My 200A pouch cells reached the dangerous point early as @ 25.1V , that cell 3 is 3.00V already .
I insist a deep discharge when assembled to let myself an estimation of the furthest I should discharge .
Also won't leave home without a 4-digits voltmetre , and a cell monitor .
Voltmetre tells me a lots , say anything is dragging , larger current up an incline that I should be easy on throttle , and when I should turn the cell monitor on .
Cell monitor tells me when to . . . . . STOP . . . . .![]()
The 9pins XH 2.54 connectors can be found at any RC shop .
i like to do the way i think you did - all tied together -
do you think it could have been just a bad cell from the start ? Since it turned out that Group 3 was the weakest of the bunch - but Group 1 gave me the problem - its possiable i never went below the Min. Volts during riding if thats the case ?
how do you tackle hills then ?
i was under the impression that lithium wasnt going to have the same issues as Lead going up hills etc, - and it dosnt to some extent - i understand it has to drop some under load - no matter what kind of battery is being used - but i didnt think i needed to be worried about the hills -
i wonder if the bad cell had anything to do with how it felt going up hills - when i repeat it in the summer - i see how the chair reacts - with the monitor this timeif i can keep an eye on it while going up at the same time -
Burgerman wrote:Thats perfect, and as I expected...
And 107Ah returned, so a pretty full discharge/charge
You have no faith in me!![]()
Now, STOP WORRYING!
shirley_hkg wrote:;) Maybe 180Ah is feasible .
Also by ATL .
IR @0.4mΩ
£22.70
shirley_hkg wrote:![]()
Found this too , and think you'd give it serious thought .
Look at the super low internal resistance , and tested capacity .
I'm quite confident that you can fit 16 of them in it , and that's 150Ah .
Should be good stuff . 0.36mOHM @ 2.65V That's really good , itsn 't it ?
@£17.00![]()
shirley_hkg wrote: Yes , they are still available . You have to judge its quality basing on the superficial information , IR and recharged capacity . Risk on / off .
http://c.b0yp.com/h.5mdPXP?cv=TvGoZtJH23z&sm=7abfba
Seller's reply is standard : THIS is NOS , and stored at 2.7V from factory .
Users browsing this forum: Williamclark77 and 459 guests
