if i am wrong as i go along here - i am sure BM will jump in to correct me
i am using 15ah Cells - 16 of them - for 30ah pack - two Rows - easily hang this in a Messanger bag on the rear of the chair and plug it in a cable which would be connected to the batteries in the chair - SB50 - thats the connector of choice - but you are free to use which ever you like - in my case - on the chair end is a SB50 - but on the battery end i will be using a XT90 - reasons for this is - its very hard to connect and disconnect the SB50 - for me and for my girls - this pack will be charged separate from my Chair pack - so i need to disconnect it each time i charge it - the XT90 will make that easy to do - i have been using 10AWG wiring for this cable - you can use 8 AWG if you like - i have been using 10AWG for a while on my other chair and have no issues so far - my reason again for using 10AWG is the XT90 connectors are not large - so even 10AWG was a little work to solder to them - but i Wont go below 10AWG cable for the connection to the chair -
if you like you can also 8 AWG cable on the chair end - in my case again i have 10AWG because i am using XT90 connectors there also - very tight room and those fit much better and easier to work with when removing etc,
they do handle up to 120A - and 90A constant -
here we go -
First Step -
Buy the Cells you want to use - i am using 15ah Cells - 16 Cells -
charge them and let them sit as been told many times on here - keep track of the Cell numbers - how much you put back in mAh over a month of discharge or longer - which ever you like - mines happen to be sitting for 3 months - i wasnt in a rush and got busy with other things -
but at least a good month is fine - anything more even better -
when your all done recharging them and taking down the mAh returned - then you want to group them to make a close pack - i believe thats discussed already how to do that - i just say it quickly - if i miss a step - please correct me
Add up all the cells discharge amount - then divide that number by 8 - and thats the target number you like to reach with each Cell group -
in this pack i just made - i managed to get the lowest to be 162mAh - and the highest 165mAh - but i did have 24 cells to work with - which i only used 16 Cells - so numbers will vary -
i will post pictures of the orange blocks - how to arrange them for the bottom row - and the Top which is different - i use 4 hole bus bars mostly - 2 hole is fine also - if you needed
Hope this helps anyone who like to see pictures along with details of how its done - i know i like to see the pictures
