rustyjames wrote:Thanks for posting this, I always wondered how they were put together because back in the day it was touted as the mother of all powerchairs. I haveto say that I'm not impressed with that frame at all. Why are going to solid mount the motors?
Burgerman wrote:How wide is that?
rustyjames wrote:I have the same issue, shrinking photos. I also use my iPad for pictures these days, just so much easier, and the quality isn't bad.
What control system and motors does it have?
hotwheels_75 wrote:rustyjames wrote:I have the same issue, shrinking photos. I also use my iPad for pictures these days, just so much easier, and the quality isn't bad.
I used the mail app for all the pics posted here so far. If you start a new email & put your own email as the recipient then insert the photos you want to shrink. Up on the CC/BCC/From line, you should see the word Images: and a size
like Images: 749 KB if you tap that line you should get an option to select the option of Small, Medium, Large, Actual Size. You just pick the one with the file size that meets your needs. Only prob is the option doesn't always show up.
Gnomatic wrote:hotwheels_75 wrote:rustyjames wrote:I have the same issue, shrinking photos. I also use my iPad for pictures these days, just so much easier, and the quality isn't bad.
When posting pics here I usually upload them to a free image hosting site like PostImage. Have it set to the resolution I want, usually 1024x768 or 800x600. After uploading, copy the direct link.
Thanks for that info, Gnomatic, when I get some free time I'll try that.
Then just put the cursor in in my comment where I want the pic to be, and click the IMG tab above the comment box, and paste the link in between the brackets that appeared in my post after hitting the IMG tab. so it looks like {IMG}www.mypic.jpg{/img} ( i used {} in place of the regular formatting brackets [] around the IMG and /IMG so the forum didn't try to display my example text as an actual pic)
Pics appear in my posts as desired and the forum software doesn't throw a fit because the file is too big.
rustyjames wrote:
When posting pics here I usually upload them to a free image hosting site...
rustyjames wrote:So, driveline wise it's the same as a Quickie 626. I'm assuming the controller is 80 amp? Mark etal. over WCJ site used to bash the Quickie and what a piece of junk it was. I'm sitting in one as I write this. The Quickie frame has it all over the Blast, and it's aluminum. The weak part of the 626 was the wheel/keyway, but I never had any issue, just had to check the retaining nut for tightness periodically.
Gnomatic wrote:Nice work, I like how you reoriented the battery area to make the chair more narrow.
Also, you should be able to stuff a good amount of Lithium in there now.
Burgerman wrote:Cant you get longer shox or extenders like https://www.google.co.uk/search?q=shock ... 88&bih=558
CBOL markets its gas springs and dampers under the Duracap® brand name.
woodygb wrote:CBOL markets its gas springs and dampers under the Duracap® brand name.
http://www.cbol.com/gassprings.html
rustyjames wrote:I don't know if you have McMaster-Carr in Canada, but that's where i buy them; I haven't been able to find them cheaper, and quality is always very good. Ebay is another possible source, but searching there for these might be painful. Here they're referred to as "gas springs."
rustyjames wrote:Is there any manufacturer, or numbers numbers on the damper? I've gotten lucky a few times and searched what I could find stamped on them. Or, you could always contact Mark Smith and see if he can supply that info. He was the main man behind the development of the Blast. He always seems willing to help fellow rollers in need
Users browsing this forum: Bing [Bot], Burgerman, Kande_ian, LROBBINS, Mr TT, Raro and 159 guests
