snaker wrote:. I intend to remove that nylon so I can put batteries close side-by-side in the battery box and precisely measure the connection bars. Is there any problem if batteries are naked without nylon wrappers.
Burgerman wrote:Interestingly the headway style cells casing does not appear to be connected to the plus or minus.
Burgerman wrote:So they are connected.The can is neg or pos?
snaker wrote:My battery box is too small. If adding just a couple of mm tape, the pack cannot fit the box.
Burgerman wrote:You want: 10 sq mm cable, 6mm stud. http://www.ebay.co.uk/itm/Crimp-or-Sold ... MNxFyXH0QA
Or for 5mm cable you want these, with 6mm stud. http://www.ebay.co.uk/itm/6mm-Battery-S ... NXL0dSXYDg
Users browsing this forum: emilevirus, JazzyBand, jefferso, slomobile, Superchunk, Yennek and 550 guests
