Burgerman wrote:You are going to need another person to help, that has some knowledge and a good multimeter. It is going to need some deductive powers. And you will find out what is wrong by careful testing. But judging by your questions and obvious unfamiliarity I suspect you will need a dealer to investigate it.
I would get my carer to take off actuators etc and test/measure them on my bench (my bed!). And do the same with position sensors, motors, etc. And be sure they were positioned correctly. And check cables by multimeter and by substitution. And after that change actuator module to see if that was the issue. If needed I would test the whole system all together on the bench, and try to figure out where the issue is. Including looking for faults on loom, motors, freewheel, brake, and error messages in the programming.
LROBBINS wrote:The position sensor(s) is (are) somewhere, almost anywhere, on the seat assembly, not IN any of the modules. Sensor(s) will be connected to one of the modules (probably the AAM) by a cable. If you have a bad component, no amount of programming will fix it, but you may be able to program the chair to IGNORE the inhibit.
Burgerman wrote:Do not remove battery! It keeps memory alive maybe, but could just be clock. No idea. But it wont help. You cant just randomly assume a module if bad, and its unlikely to be that anyway.
LROBBINS wrote:I'll take a stab at that last question. The most common way that end-of-travel switches work is that there's one for extended limit and one for retracted limit. They are normally closed and when pressed by a cam on the actuator the contacts open. Each one has a diode in parallel with the switch, however, so that even though the circuit is interrupted in one direction, it is bypassed in the other direction. So, for example, if the "extend" limit switch is pressed, it will not allow any more current to flow in the extend sense, but the diode will let current pass in the retract sense. If a diode has failed so that it no longer conducts, if you reach that limit you can't go back. Is that what your chair does? If it is, there's probably a bad diode. Oftentimes the switches and diodes are actually inside the actuator, so can be a bit of a pain to repair - but it can be done.
I very much doubt that the controller uses time to infer position. If the actuator has an encoder, it can count pulses of the encoder to know position, but then there'd still be wires connecting it to the control module. I've never seen this on a chair, but it's also possible to have position sensors inside the actuator. I think that there was also at least one chair that used a potentiometer that was moved by the seat to give position information. In any case, a thing to check is how many wires are in the cable that connects the actuator to the electronics. If there are more than two wires, there's something more than just a motor (and possibly internal limit switches) inside the actuator.
woodygb wrote:laoshanren wrote:woodygb wrote:This post is purely to help anyone searching the forum..
Q-Logic and Curtis discussion has moved threads.
viewtopic.php?f=2&t=1965&start=100#p26123
For those that want a mobility scooter serial interface ....
Hi woodygb thanks,
May I take a shortcut, I made a connector like the picture:
1. whats the other end should do, soldering to a USB? or need use the IC1 MAX 232?
2. what software should I use? or any thing else ?
Best
Adam
All you need is one of these ..
http://www.ebay.com/itm/USB-CAN-USB-to- ... 0899053368
AND the DLL from this link.
viewtopic.php?f=2&t=2757&start=340#p73389
FOLLOW THIS GUIDE.
NOTE THAT THERE APPEARS TO BE 2 TYPES OF THIS CAN
Some info for you here on the newer USB-CAN...
viewtopic.php?f=2&t=2757&start=340#p73334
viewtopic.php?f=2&t=2757&start=360#p87375
Cheers Woody
LROBBINS wrote:Yes. Two larger wires = motor, two smaller wires = parking brake.
woodygb wrote:IMO.
It LOOKS like multiple connections... BUT IT'S NOT... A blade slides between the ( 4 ) contacts.
Each end in your pic is A SINGLE CONNECTION ... the middle is just 2 connections.
http://www.terminalcn.com/products.asp?sortid=2
Burgerman wrote:Thers 6 possible wires coming from a wheelchair motor.
Always used - two big power wires to drive the motor.
Almost always used - 2 thin wires to release the brake and allow you to drive.
And very occasionaly a shaft encoder, 2 wires or occasionally 3, for an encoder. This tells the controller if the chair is going straight, turning etc. Used on some speciality controls for those that struggle with normal joystick controls. It is a feedback system for the motor/controller.
and can I control the motor and brake together, I mean use one relay?
Burgerman wrote:Brake may be 12 or 24. Dont get it wrong because either way causes damage.and can I control the motor and brake together, I mean use one relay?
That sentence makes no sense to me!
What do you operate it with?
A powerchair controller and power module normally.
Burgerman wrote:As long as you dont feed the brake 24v and it is a 12v brake, as it will burn out. And as long as you dont feed 12v to a 24v brake as it will will not realease properly and will rear out the friction surfaces fast. You also really should limit current somehow too as the starting current will be 150 to 200A INITIALLY as it begins to turn. Maybe a couple of headlamp bulbs in parallel, and in series with the motor, but not the brake.
Burgerman wrote:A wheelchair motor when measured correctly will be far lower than 1 Ohm.
They typically have stall currents LIMITED by the controller to 80 or 120A per motor.
A 1 Ohm motor would draw about 25 amps only if stalled! Unless this is a tiny scooter or folding lightweigt powerchair this is extremely unlikely.
Brake voltage may be marked on the motor. Or measured on the chair, or checked by looking in programming. Or tested. If it realeases fully at around 8V its a 12v brake.
laoshanren wrote:Hi good morning,
Just wonder if any body know where is the tilt sensor for Q6 EDGE chair?
Best
Adam
Hi woodygb thanks,
Best
Adam
FOLLOW THIS GUIDE.
Cheers Woody
woodygb wrote:Yes.
Assuming that you have the Curtis 1314 PC Program AND the modified LXN4py2s.dll file AND the CORRECT QM_USB.dll AND the mcp.zip .....
..... and combined these properly as instructed in the guide.
woodygb wrote:Yes.
Users browsing this forum: Bing [Bot], emilevirus, Superchunk and 285 guests
