Q logic/Curtis Cable end
Re: Q logic/Curtis Cable end
Postby woodygb » 11 Nov 2017, 11:29
laoshanren wrote:
woodygb wrote:Yes.
Assuming that you have the Curtis 1314 PC Program AND the modified LXN4py2s.dll file AND the CORRECT QM_USB.dll AND the mcp.zip .....
viewtopic.php?f=2&t=2757&start=360#p87375
..... and combined these properly as instructed in the guide.
Hi woodygb,
update a little is I got the: 1314-PCPS_OEM_4-6-7-467, seems works in win7, is this version ok?
Best
Adam
1314-PCPS_OEM_4-6-7-467 is the latest Curtis version it may or may not work with the LXN4py2s.dll and QM_USB.dll .
NOTE:- That the MCP file will not be needed in this later version.
But it will not harm to try.
Check your P.M.
Use the earlier version.
Replace the original LXN4py2s.dll with the modified/downloaded LXN4py2s.dll.
There are 2 versions of the USB-CANBUS .... the CORRECT QM_USB.dll depends on which model you have bought...place the QM_USB.dll in the 1314 directory.
The downloaded MCP file replaces the existing one in the OLD 1314 Global directory.
Postby laoshanren » 11 Nov 2017, 13:21
woodygb wrote:
laoshanren wrote:
woodygb wrote:Yes.
Hi woodygb,
Best
Adam
Check your P.M.
Hi woodygb thank you for every thing,
You mentioned there are two versions of USB-CAN, can you find out what kind mine is from the pictures attached?
Or how to find out it?
Best
Adam
laoshanren
Postby woodygb » 11 Nov 2017, 13:52
Original QM type ..see logo just above the word USB.
This requires the original QM_USB.dll
LMDZ Version ...this requires the LM_USB.dll to be used ..download ... https://1drv.ms/u/s!AkMTZUw5KF1egimcMDZXrJjPRJ5x and rename it QM_USB.dll
Postby laoshanren » 11 Nov 2017, 21:18
woodygb wrote:Original QM type ..see logo just above the word USB.
Hi woodygb thanks,
My USB-CAN is the second one, and I renamed the DLL, installed SETUP.EXE and copied the dlls, then hook up the two wires to the chair, when I used the 1314-4402, which may have no complete install? at least it's Options has much less items see pic.1. but the 4402 did some thing when click connect, see pic.2. almost done but stopped at any reason see pic.3 please.
As 1314-4401 has a more formally menu look like, but never do any thing and just say initialization error see pic.4, can you help what's wrong I am doing here?
Sorry the bad pictures.
Best
Adam
4402's menu
4402 connecting
4401 no work
laoshanren
Postby woodygb » 11 Nov 2017, 21:33
Have you followed this guide for the 1314-4401 and selected ALL the correct Coms options?
viewtopic.php?f=2&t=1965&st=0&sk=t&sd=a&start=216#p26731
With the 1314-4402 you will need to select the correct serial port number and MASTER MODE in Communication
Postby laoshanren » 11 Nov 2017, 22:14
woodygb wrote:Have you followed this guide for the 1314-4401 and selected ALL the correct Coms options?
Hi woodygb thank you,
Your word is a miracle, the device manager set the com 5 and the 1314 cached com 5, just no work before, now works after reset them.
I attached pictures here, can you tell me what should I do next to:
1. download the software to my computer;
2. overcome the red 'STOP LIGHT' on my joystick, some one said can ignore the tilt?
Best
Adam
laoshanren
Postby laoshanren » 11 Nov 2017, 22:54
The last post is just hook up the power module, without the Advanced Actuator Module, here are pictures with AAM see picture conn_3 .
Seems I can't do much, I clicked [system/device parameters], it run a while and then error window out. see picture conn_5.
what can be the reason?
Best
Adam
laoshanren
Postby woodygb » 11 Nov 2017, 22:58
Not sure.
Can you save and send me the par file?
Postby laoshanren » 11 Nov 2017, 23:11
woodygb wrote:Not sure.
Thanks woodygb,
I just don't know how to save the program yet, I clicked a button in the top right of the 'save ...' , the machine is running 10 mins already. I should use a better computer.
Best
Adam
laoshanren
Postby woodygb » 12 Nov 2017, 01:08
Have you tried with the later 1314-4402?
NOTE :- I have never tried the later PC Programmer version with the CAN-BUS .... I maybe wrong about suggesting MASTER mode as the older version uses SLAVE ...also note that the later version has some built in anti tampering software that is intended to prevent the use of homebrew interfaces ...so it may not work with the A1 USB-CAN.
Postby LROBBINS » 12 Nov 2017, 09:07
and what Adam did
Postby laoshanren » 12 Nov 2017, 13:17
woodygb wrote:Have you tried with the later 1314-4402?
Thanks woodygb,
You are right, I did test a little of the new version, signed the com, no connection. I didn't go too far, seems the adapter is not right?
Do you know what's the command in 1314-4401 or 1314-4402 to save the program? I think it is the first thing I should do when connected.
Best
Adam
laoshanren
Postby laoshanren » 12 Nov 2017, 13:20
and what Adam did
Thanks LROBBINS,
No that discrepancy, the first paragraph mean the first .dll, and the second mean the second .dll.
Best
Adam
laoshanren
Postby woodygb » 12 Nov 2017, 13:22
mcp.zip
(133.83 KiB) Downloaded 243 times
The MCP directory file replaces that of the EARLY 1314 ...You will find the MCP directory in the Global dir of the 1314 program.
QM_USB.rar
(213.84 KiB) Downloaded 279 times
... This is the LMDZ USB file RENAMED ALREADY to QM_USB
LXN4py2s.zip
(48.47 KiB) Downloaded 249 times
....This file REPLACES the original LXN4py2s.
Postby laoshanren » 12 Nov 2017, 14:20
woodygb wrote:
mcp.zip
QM_USB.rar
LXN4py2s.zip
Thanks woodygb,
That all done.
I can't find the command to save the program now, are there any help file or tutors?
Also a slow action, when I try to check any modules' parameters, it takes long time and finally error.
Best
Adam
laoshanren
Postby woodygb » 12 Nov 2017, 14:48
Hmmmm ...I think that I remember someone with a similar problem that was solved by using using shielded cable from the USB-CAN to the plug....I'll look back thru the threads.
In the meantime try twisting your cables together.Image
Postby woodygb » 12 Nov 2017, 14:59
viewtopic.php?f=2&t=2757&hilit=shielded&start=260#p54445
The recommendation of that part of the thread appears to be.... use WINDOWS 7 and 2 wires in an Ethernet cable as the lead.
Postby woodygb » 12 Nov 2017, 15:11
BTW ...You can take screenshots by pressing shift and Prt Scr together on your keyboard...then pasting the result into M.S. Paint and saving....like this.
Postby Burgerman » 12 Nov 2017, 20:36
Shift no longer needed.
Postby laoshanren » 13 Nov 2017, 13:27
woodygb wrote:http://www.wheelchairdriver.com/board/viewtopic.php?f=2&t=2757&hilit=shielded&start=260#p54445
Thanks woodyg,
I tried twist the wires, short the wires up to 12 inch only, all the same.
Its better to take screenshots than Snipping, I'll make pictures that way.
I am searching the tutors on youtube, lot of them with handhold program...
Best
Adam
laoshanren
Postby laoshanren » 13 Nov 2017, 17:00
woodygb wrote:BTW ...You can take screenshots by pressing shift and Prt Scr together on your keyboard...then pasting the result into M.S. Paint and saving....like this.
Thanks woodygb,
I shift to another computer better, I saved the powerbase-parameters and aam parameters, and I used the parameters file editor open it, but I can't find where and how to ‘IGNORE’ the actuators, which I was told can changed my STOP LIGHT red on and let me be able to operate my chair.
I forward them to your PM, can you help me please.
Best
Adam
laoshanren
Postby laoshanren » 13 Nov 2017, 18:44
Hi woodygb thank you very much,
My chair working now.
I din't find where to put the "IGNORE" yet, I just pull the device parameters, and modified the actuator's limited angle to the maximum,here is 78°, write to system, the red led disappear after power circle.
Best
Adam
laoshanren
Postby woodygb » 13 Nov 2017, 23:39
I also cannot find any "ignore" function in the parameters.
Glad that I could help you . :)
Postby laoshanren » 14 Nov 2017, 03:20
woodygb wrote:I also cannot find any "ignore" function in the parameters.
Thank you woodygb,
You helped me lot.
I guess its possible to reverse the joystick direction by program, will try later.
Checked the speed all set 100% already, don't know how to increase the speed yet.
Best
Adam
laoshanren
Postby woodygb » 14 Nov 2017, 09:32
...possible to reverse WHAT in response to the current joystick movement?.. The actuator direction or the drive wheels?
Postby laoshanren » 14 Nov 2017, 21:40
Thanks woodygb,
I need reverse the joystick's forward and backward.
I don't use the joystick to control the actuators, I designed a relay circuit to do that.
Best Adam
laoshanren
Postby woodygb » 14 Nov 2017, 22:23
...what about left and right turn ...is that also reversed?
Postby laoshanren » 14 Nov 2017, 23:45
Thank you woodygb again,
Do you know the 6 pins wire out of the Q6 joystick?
Best
Adam
q6 joystick.JPG (19.78 KiB) Viewed 9217 times
laoshanren
Postby woodygb » 15 Nov 2017, 01:44
enAble 50 stuhlabhangige Parameter.zip
(13.65 KiB) Downloaded 260 times
Postby woodygb » 15 Nov 2017, 22:33
Adam,
Could you please answer this question..... as the solution may be to simply swap wires around at the MOTORS.
Cheers Woody
Users browsing this forum: acid_coke, duke1, faico_26, jefferso, LROBBINS, robertnew16, saker98 and 566 guests
