steves1977uk wrote:The PL8 gets confused whether to buck or boost. A lower voltage PSU is ok to use, but a higher voltage PSU is preferred since the PL8 has to work less hard trying to boost the voltage. A 27 to 30 volt 40 amp PSU would be better to use.
shirley_hkg wrote:steves1977uk wrote:The PL8 gets confused whether to buck or boost. A lower voltage PSU is ok to use, but a higher voltage PSU is preferred since the PL8 has to work less hard trying to boost the voltage. A 27 to 30 volt 40 amp PSU would be better to use.
BM said it happened only at start .
Instead , I found it lingers through out the entire charge .
Now I set the PSU supply voltage out of that of my charge range; 24V ---- 29V .
// Firmware History
// 4.06
// - FEATURE: Added model ID reset API for manufacturing QA app
// 4.05
// - BUGFIX: Battery history upload sometimes skipped
// - BUGFIX: Favorites sometimes not showing in list
// - BUGFIX: Disable Favorites not working if favs already exist
// 4.04
// - BUGFIX: Controller sometimes reports a model ID of UNKNOWN
// - BUGFIX: PL8v2 will auto-start with only balance lead connected (should wait for mains connected)
// - FEATURE: Trickle charge support for NiXX/Pb (both Trickle-only operation and trickle after peak)
// 4.03
// - BUGFIX: Minor UI rendering cleanup (Cell IR warnings, numeric value edit, etc.)
// - FEATURE: 'Show Power Supply Select screen on startup' option
// - FEATURE: Improved grouping/ordering of Settings
// - FEATURE: Optional 'Simplified' UI mode (hides subview details)
// - FEATURE: Feature Controls for restricting capabilities
// (parallel charging, multi-pack, manual, favorites, rate adjust, clear setup on complete/stop/error, BumpTag/preset editing, settings access, auto-starting)
// 4.02
// - FEATURE: Total power supply input limit (across multiple chargers)
// - FEATURE: Redesigned power supply options screen (simpler and faster)
// - FEATURE: On-the-fly amps adjustment during operation
// - FEATURE: Support for NiXX fallback voltage adjustment (BumpTags, Battery Presets, and Manual)
// - FEATURE: Show 'No Main Power' error when PLT is powered via USB cable
// - BUGFIX: Battery Settings values for a preset are reset to defaults when editing an existing preset
// 3.05
// - BUGFIX: Enable History Upload setting in BumpTag is sometimes disabled
// - BUGFIX: Battery Details option not showing in popup menu
// 3.04
// - FEATURE: Enabled Battery History Upload by default
// - BUGFIX: On rare occasions, invalid CRC errors reported
// 3.03
// - FEATURE: Manual operation support for CCS app unbalanced charges (unified app only)
// - FEATURE: Signaling changes for improved reliability (unified app only)
// 3.02
// - FEATURE: Monitor moved to operation menu to make room for Back/Clear button
// - BUGFIX: Cached batteries are sometimes incorrectly shown as a Preset
// - BUGFIX: Large/invalid cell IR values at beginning of charge
// 3.01
// - FEATURE: Battery Presets support
// - FEATURE: Unbalanced charging support for Manual
// - FEATURE: Per-BumpTag history upload enable setting
// - FEATURE: Support for naming Bump Controller (visible in mobile CCS app soon)
// - BUGFIX: Stopped operations sometimes show as DONE (instead of STOPPED)
Took a few years though!
Then I might do my keyboard/mouse! Yesterday, topped up my 3 multimeter batteries, my quadcopter packs, RC transmitter, the RC Bot, FPV monitor, FPV goggles, and to lots of aaa cells from my house phones. Then I can relax for a bit with everything done other than my automower... And TV / other remotes - all aaa cells.steves1977uk wrote:https://www.rcgroups.com/forums/showthread.php?3040760-PowerLab-6-not-initializing
You should ALWAYS power up the charger before connecting any battery packs to avoid issues like in the link above. Just a heads up!
Burgerman wrote:Are these the same fuses that are used to drive the chair? If so they will be at least 80A.
Burgerman wrote:If driving the chair runs through them, they must be good for at least double what the charger can do. If they were put there JUST for charging, then who knows.
Users browsing this forum: Maxsos and 78 guests
