Burgerman wrote:Yes only more so. Because 3.5 wide rim is INSIDE the wheel. The actual wheel is 4 inches across. The tyre is only 3.5 inches.
Burgerman wrote:The reson its there is because if you tilt, esp when high up, or on anything but level ground the chair may tip over backwards as you move forwards. Made worse by moving the seat back. So recline, and tilt can be dangerous! Especially if seat is raised. But its common sense to me so I use my brain.
Burgerman wrote:Yes, thats what I did, over a bed since it feels high and may tip. With recline as well as tilt its a close thing. Esp if high... So I dont recline if high. And until you get a headrest fitted you cant really!
300mm or 12 inch lift doesent sound much. But it certainly feels like about 3x this! Its not something I use much though. Its too slow to rise/fall, lifes too short. But can be useful at times to reach stuff.
shirley_hkg wrote:Same price now !
Burgerman wrote:No tubeless bead!
Scooterman wrote:PS. Can you stick a tube in a tubeless?
Burgerman wrote:At a guess, all wrinkly, and not stuck well. And you will wish it was paiunted gloss black!
hank wrote:If all fails
Can of black etch primer
Can of clear lacquer
Buff up Sorted.lol
Unlikely. Have you had it up high at max tilt/recline yet?If it had of tipped would the anti-tips have saved you?
Burgerman wrote:Two more of my chairs. Note joystick position. To the left of the arm, and the plastic body, a little higher than the arm.
http://www.wheelchairdriver.com/images- ... chairs.JPG
Users browsing this forum: Seafighter and 58 guests
