Is it advisable to machine this 3-piece adoptor in one piece ?
Burgerman wrote:I like your new flat light cables!
Burgerman wrote:You mean seat dump angle, not bucket.
shirley_hkg wrote: Can you tell the vertical axle info of caster fork ?
Maybe I can help .
Burgerman wrote:Be careful, my frame rails are different as I have no more holes for the front bolt! Look at the position of the plastic cable cover, at the rear as those look similarly positioned. But you seat is further forwards on the top.
Burgerman wrote:IF the plate were steel, and 6mm thick, the 2.75 wheel with the 350 tyre could be used. But thats very thin for a strong thread or counterunk bolts. That would move the wheel in by 10mm, and the tyre would be 90mm instead of 120mm. So would have an over large 11 mm gap between motor and tyre instead of 3...
.I can proceed with trying to introduce bucket into the T/E unit, it's virtually dead horizontal at the moment.
Bucket refers to the curve of a seat back and high side bolsters to prevent cornering throwing you sideways.Burgerman wrote:Softening the spring cannot be done by removing preload... That changes only ride height. You just lowered the rear a bit. You didnt soften it unless the spring didnt move at all. You can get softer spring/shock units. Mine are black, hard.
Burgerman wrote:*Dump!Bucket refers to the curve of a seat back and high side bolsters to prevent cornering throwing you sideways.
Burgerman wrote:*You can throw away the horizontal bar and mount lights where it bolted on. Its not needed.
Burgerman wrote:*And you can get black 9 inch tyres, and they are 280/250 - 4. Expresso is driving about on some!
2 of each here! They may even be better as the footplate will fit more easily. https://www.ebay.co.uk/itm/Set-of-4-Bla ... SwcGBaqUdY
Burgerman wrote:And you can get black 9 inch tyres, and they are 280/250 - 4. Expresso is driving about on some!
Burgerman wrote:Ribbed?
I have never used a ribbed tyre in 22 years.![]()
It has to be thick enough . 10mm at least .
Therefore , turning the rim inside out is worthwhile .
Sadly that I don't have the hub , or I can clone one completely fitted .
Burgerman wrote:Also there are 3.00 x 4 and there are other 3.00 x 4 tyres. Those are nominal sizes. Meaning they are ABOUT the right size... They vary a little.
The ribbed ones are about 10.3 inches and so are the rear 3.00 x 4 on your scooter. And they will hit your footplate.
The best 3.00 tyre is the one I keep linking to as its 9.5 diameter and misses the centre footplate better and is a quality high load rating tyre by heidenau or whatever its called.
https://www.ebay.co.uk/itm/Heidenau-MSC ... SwNnRYhLX9
https://www.ebay.co.uk/itm/Motorradreif ... Sw68lamT4w
https://www.oponeo.co.uk/moto-tyre/heidenau-msc1
http://www.keiyama.eu/heidenau-msc1-3-0 ... m_store=fr
https://www.tyres-pneus-online.co.uk/mo ... -35-b.html
https://www.mytyres.co.uk/rshop/Tyres/H ... B/R-166482
https://www.amazon.co.uk/s/ref=nb_sb_no ... SC1+3.00-4
https://www.tirendo.co.uk/heidenau-msc1 ... 66482.html
Would you mind linking to a valve for me? Also does the valve have to be glued into the rim to stop the air escaping as you're pumping the tyre up?Burgerman wrote:The centrenut, will also require the rim to be spaced 16mm with 1.5mm centre cover to miss the nut...
never bought tubeless before and thought it's no good me buying a tubeless tyre and not knowing what valve to buy, that would be silly!Would you mind linking to a valve for me? Also does the valve have to be glued into the rim to stop the air escaping as you're pumping the tyre up?
Also if you happen to be moseying past your salsa with a pair of vernier callipers in your pocket could you measure the Heidnau's at their widest point. I think my forks might be a tad narrower than your's?
Users browsing this forum: Burgerman, duke1, emilevirus, LROBBINS and 128 guests
