Hello!
Greetings from Spain. I’m Fran and I’m modifying an Invacare Mirage to make it look cooler.
Usually I use the common known grey solid rear tyres 12 1/2 x 2 1/4 (62-203) but I just received a pair of black solid tyres which are 12 1/2 x 2 1/4 (57-203). I tried to find the differences between these 2 sizes (57 or 62) but I didn’t get a clear answer. In theory 57 should mean 57mm outer tyre diameter and 62 would refer to 62mm, is it? But both tyres are 2 1/4 which also refer to tyre width.
Burgerman wrote:Where to start.
Rims. Are in inches. Typically stated as for e.. 8 x 3 or in the motorcycle or car world 8 x 3J and thats the same thing. The 3 part is the rim width where the tyre sits. Half an inch either way does not stop you fitting a TUBE or TUBELESS type air filled tyre. But is a big issue if you are sing those horrid foam filled or polyurethane filed tyres.
Your 12 1/2 x 2 1/4 is the tyre size. What is lacking is the rim measurement. So it should read 12.5 (12 1/2) x 2.25 (2 1/4) x 4 or 6 or 8 which is the rim diameter. Tyres are what is called NOMINAL sizes. That means that if you buy 6 similar sized tyres from different manufacturers they will all vary in external size slightly. But will all fit the rim exactly. That means when you measure them they will not be what you expect. Your MM measurements like (57-203) show that. And its a small difference that make no difference to your usage. In this case the 57 is width. 203 is diameter. 5MM either way will be unnoticeable. R means radial ply.
- specifically12 1/2 x anything - 203 mm Juvenile, scooters
A general guideline is that the tire width should be between 1.45/2.0 x the inner rim width.
If you pull the beads apart and measure the total width from bead to bead, it should be approximately 2.5 x the ISO width.
Burgerman wrote:Tubeless tyres need tubeless rims.
So that means they are one part, have a special ridge to seat the tyres securely, etc. And I think finding a tyre that narrow that is tubeless will be impossible.
One of the reasons the ride is harsh is solid tyres... The other is that the chair has very little suspension travel. And small wheels and no front suspension.
You really need bigger tyres with a larger cross setion so that you need less pressure to support the weight. Thats why I fit wider rims, fatter tyres to all my chairs as the spasm I suffer cannot stand the skinny tyres or "flat free" solid ones its literally painfull! Dont know how anyone can run those.
But you have no front suspension and rock hard solid small casters too. So punished at both ends.
Burgerman wrote:Estas sillas miden 64,5 cm de ancho y 65,7 cm de alto
Users browsing this forum: No registered users and 367 guests
