Burgerman wrote:Then the pack is WAY out of balance. Why?
So it can only charge at the same rate that the 1000mA balance circuit can drain the 3.6V cell. So you have a problem. And may need to restart after 16 hours if its not already done. The full cell wont much like being full for long periods. So you can speed things up by connecting say an automotive headlamp bulb across the 3.6V cell for a few minites. Watch on screen. Its voltage will fall, and the charger amps will increase.
Burgerman wrote:I numbered them on your image.
Your nine wires. Are in fact 0 neg wire start, then every plus terminal is cell 1, 2, 3, etc.
The neg or 0 wire goes where shown as 0
Every other + cell terminal then follows on as marked. So...
1 is the first cell.
5 is cell 5.
8 is cell 8 etc - i missed some out.
Dont get it wrong because you COULD smoke the PL8.![]()
Its hard to do that he says. Because the sides of the white PL8 balance lead is marked with red and black.
Burgerman wrote:OCP probably means over current protection. What power supply is it?
Did you set the supply tab correctly to take less amps from that supply than it can provide?
Did you set the power supply volts and amps to max?
The charger is set to 30A. So will take about 35A at 28V to power the PL8. Which supply do you have?
Burgerman wrote:Set about 25V and 50A.
Then in PL8 set supply tab to 10 to 30V and to 47A max...
Burgerman wrote:Yes thats because that cell is full. All the rest are not. Re read the post above...
Burgerman wrote:Leave it. If its miles out of balance its better to turn off. And charge each cell individually.
Burgerman wrote:Turn it off. If thats the case it will sit for hours trying to balance and never get there.
So charge each seperately. Or discharge the full one by the same Ah as the rest.
Scooterman wrote:Temporary connections for partially recharging matched cells in 2P8S prior to building the pack. 16 cells in a row are a bit of a stretch for the pigtails, but it's a one off and I'm worn out so couldn't be bothered to rearrange the pack into two parallel packs.
I just wanted to say how nervy I was making all the connections. I dread to think what a nightmare 72 headway cells are to arrange
terry2 wrote:
I felt the same.
My pack has charge and balanced(I think)
Burgerman wrote:Scooterman, how do you get all those cells to stick upside down and the laptop too?![]()
Burgerman wrote:I wont be needed soon. We have expresso and scooterman, all figuring this stuff out and 3 or 4 others.
Users browsing this forum: shirley_hkg and 128 guests
