shirley_hkg wrote:cheers
shirley_hkg wrote: Ex_gooserider got some last year.
It is £25 each. Tubeless.
Sadly, postage requires 1.5X of that ..
rickystyx wrote:I goth these wheels and tyres - tubeless and 10psi max
https://www.ebay.co.uk/itm/quad-bike-go ... 2749.l2649
i just fitted them with some adapters I had made by R and R alloys - the adapters were £95 including postage and vat etc but they were made exactly to my specs
Don't know if these links will work or not but I'll give it a go https://www.facebook.com/RickyStyx/vide ... =3&theater
https://www.facebook.com/photo.php?fbid ... =3&theater
I'm really happy with the result - the wheels did need the inner hole sanding to debur them so that they would go on and off but that only took about 30 seconds each wheel. I also opened the stud holes out to take m10 bolts
I could have made the adapters thinner but I wanted to make it easy to get my hand / brush / sponge in between the chair and the wheel for cleaning as I found that with the original wheel I had to remove it to be able to get rid of the mud etc collected when going out in the countryside.
rickystyx wrote:I'm laid up today but I'll try to get the measurements tomorrow or Saturday.
Just for your info the pcd is 90mm not 78mm and they ake m8 bolts - the stud centres are 78mm apart.
R and R would make thinner adapters than mine for less - really easy and only took a couple of weeks to get
I'm nothing to do with R and R but they did make exactly what I had designed
Cheers
Richard
peace
Burgerman wrote:Casters are too skinny and small off road on the soft stuff. Can you not fit 3.00 x 4 tyres / rims?
for any help,peace
Users browsing this forum: emilevirus, LROBBINS, shirley_hkg, tettralytic and 162 guests
