Burgerman wrote:Those things make no sense to me. Not even sure what it is you are searching or looking for.
If it was me I would fit a bearing that allows my to use a 12, 14 or 16mm bolt, and or a 12, 14 or 16mm caster stem. If I couldnt get such a bearing I would use a sleeve to make whatever you can get fir whatever caster or bolt you use.
Burgerman wrote:What are the stock bearings?
THEN you can begin.
Many caster forks (you need new right?) just use a bolt. And a nut. So you use a bolt that fits your new bearings, usually 12, 14 or 16mm. Or a sleeve. And then the fork.
So theres no simple answer. You must figure out what you need. Theres unlikely to be a plug and play fork. And most are even sizes and metric. At least here.
17mm sounds way bigger than you want. Are you sure? The caster barrels dont look beg enough to support bearings that bg to me. And the caster fork DOES look big enough for bigger caster tyres/wider rim already.
What bearings? Take them out, measure them, post image and dimensions. And a proper look at the caster fork disassembled.
woodygb wrote:Wipe the grease off and look at the numbers etched into the edge of the outer race.
E.G. 27 16 14 = O.D. I.D. Width
woodygb wrote:The dimensions are in centimeters and only give a general overall size of the fork.... nothing that I can see about the stem size.
Size: approx.21x7x6.5cm/ 8.3x2.8x2.6 inch
Size: approx.21cm x 7 cm x6.5 cm/ 8.3 inch x 2.8 inch x2.6 inch
Burgerman wrote:Without being there and seeing this, I suspect you need to use flanged bearings, because of crap frame design and 26 x 12 mm. And then many forks such as the ones used on the salsa will fit. Its just the fork. You fit a correct length bolt, spacers, etc to fit the bearings.
And then a 9 inch or 10 inch tyre will fit. But that frame is a terrible design.. Cheap and bodgy...
duke1 wrote:hi @burgerman idk if you missed the question so thought id try again,
i had a measure the fork shaft is 17mm and is 45mm long,i had a quick search online but can only seem to find 21 mm i dont suppose you or anyone else reading has any clues which other chairs use 17mm shaft but the 3x4 caster wheel?.or can i just find different caster fork bearing with 21mm hole?for any help,peace
ex-Gooserider wrote:shirley_hkg wrote: Ex_gooserider got some last year.
It is £25 each. Tubeless.
Sadly, postage requires 1.5X of that ..
Interestingly, they are fitted w/ tubeless tire valves, but the 3.50-8 tires are labeled as Tube Type...
ex-Gooserider wrote:duke1 wrote:hi @burgerman idk if you missed the question so thought id try again,
It is SOMETIMES possible to find an alternative bearing, but to do so you'd need a spec for the bearing outer race and the bearing thickness, which are the three numbers needed to replace any of the bearings we see on our chairs.... The first two should be marked on the bearing, and any bearing house catalog will list the third as part of the description... Essentially you would look up the specs for the stock bearing and then search for ones with the right ID and the same OD - thickness is less critical depending on how much space you have to work with....\
Also many forks (not all) have stems and forks that can be separated, and if so it would not be a terribly hard job to make a new stem that matches new forks and old stem sizes... (it is less likely that you'd find something that didn't need modifying)
If talking about the axle that the wheel spins on, the same thing applies about swapping bearings, but another option (which again requires some machining) is to make new spacers with a shoulder to fit the new bearing... (Note also that since there isn't much consistency in the thickness of the wheel hubs, you will probably need to be making new spacers regardless...)
Burgerman wrote:You want 8 or 9 inch tyres those are 280, 250 4.
I also already linked to some low profile smooth tyres in another thread or previous place here. At http://www.allterraintyres.com
https://allterraintyres.co.uk/index.php ... s_id=91756 these will fit, rim may be too narrow, use a 2.5 wide one.
9 x 3.50 4 may also fit, measure fork. https://allterraintyres.co.uk/index.php ... _1585_1586
Burgerman wrote:If they are 2.5 to 2.75 wide they will. But as usual it does not include the data we need.
I'd love to spend a grand or so on a wheelchair but it is never going to happen.
Burgerman wrote:If you want fat tyres and bigger diameter too then thats quite possible, even with a 24 inch wide chair with group 24 batts.
But to do that PROPERLY so it lasts, and is reliable long term, you need to build to AT LEAST as good a quality as the mainstream manufacturer does, and ideally better. Using the best motors, best controllers, best batteries, best wiring and loom, better stainless sealed bearings, tougher tyres, wider rims etc. And a complete redesign of the frame and battery/motor layout. The one above has a total width of 24 inches, tubeless, and a 120A lithium battery. You cannot do that cheap, or easily. Takes much work, planning and best of components.
Burgerman wrote:What happens if you go get a district nurse or doctor to get your misses assesed for a chair? And then insist its a personal budget. Thats how I pay. One call and you may start the ball rolling. I did the same for a 1600 quid alternating air matress. And am awaiting delivery.
Users browsing this forum: Kande_ian, Mr TT, tettralytic, Williamclark77 and 56 guests
