I have a question. I recently found a supplier of lifepo4 batteries that are similar in size of the lead acid.
The chair that I use around the house is beat up pretty bad but still does what I need it to do. The supplier was all ready to make a deal on 2 12v 60ah until I told him it was a 24v system and that I would be charging them separately as 12v and with a charger specifically designed to charge lifepo4 batteries.
He said that 12v lifepo4 batteries cannot be wired to supply 24v. They are not the same as lead acid was his exact words. I asked repeatedly to explain why for my personal information and that I didnt dispute his word. I never got a reply to explain. Im assuming that whenever he found out they were for a powerchair that he got scared of a liability issue. Is there a difference or are they just trying to protect the company?
Scooterman wrote:The crimped bit of the crimp is the teeny weedy square impression indicated by the arrow. IMHO a pretty shoddy job done by Sunrise. You'd think they'd use one of the Hex type crimping tools.
terry2 wrote:Scooterman wrote:You could cut some shims out of an aluminium coke can or similar.
I have just seen a funny way of wiring these up.
A guy across the street who has solar panels.
He bought 4 200 AH\Amp cells like ours for the solar energy.
He used a copper plated washer the exact size of the terminal part, so it's a perfect fit.
He had some thick plated wire and soldered that straight on to the washer![]()
The wire was spread about a 3rd of the washer. Never seen that before, so don't know what to make of it.
3. Unless working very fast and carefully, there is a high probability of having solder wicking up the wire, making it stiff and more prone to breakage at the end of where it wicks....
but my memory of what Anderson says was a bit different so I checked their literature. Here are some clips from the Anderson catalog:The Anderson technical documentation that describes assembly procedures both requires use of the 'Official' crimper and pins that match the wire size and PROHIBITS soldering - and this is on the same thin wall pins that BM insists on soldering...
APP® connectors are designed to be crimped and/or soldered to multi-stranded copper conductor wires only.
PP15-45 Silver Plated Power Contacts ... Only closed barrel contacts are suitable for soldering
PP15-45 Contact Termination Methods (same for PP75, same for PP120, and Sb series for contacts)
Crimp³ Wire Contacts
Hand Solder Wire and PCB Contacts
Solder Dip PCB Contacts
Wave Solder PCB Contacts
3 Use APP® recommended tooling only. Alternate tools may adversely affect the
performance of our connectors along with UL and CSA recognition.
silver plated PP15-45 connectors
shirley_hkg wrote:Scooterman wrote:Has anyone built a lifepo4 pack using cells with an M4 threaded hole?
If so how did it go?
P176 ↓
My long forgotten ultimate G24 form factor 280Ah is back on track, only one balance lead left.
Putting another 75Ah pouch cells together is a task.
No more bus bars. Wires and terminals only.
Initial balance was still messy.
Took two 15% DOD cycles, and now balanced in 10 mins and absorption period to 115mA termination is just another 20 minutes as well.
Burgerman wrote:Are you planning on leaving HK then? Actually looking at the news that may be wise! But not to china.
shirley_hkg wrote:May be UK as a temporary refuge ? And putting up A Storm 4 Xplore there as a backup too.![]()
Burgerman wrote:>>> BM - Can you give me reassurance then I’ll order some 12 awg locally (aliexpress).
Use the same as expresso. That looks about right. Or 10swg?
I work in mm... SWG gives me a headache! You want the one thats a size bigger than the PL8 cables. 10swg I think. Personally I would use 6mm2.
shirley_hkg wrote: Go for 10awg . Still easy to bend .
shirley_hkg wrote: I'd say NO.
Simply a thick plastic bag will do. Cut to appropriate size. Hang the sides down and tie it up.
Just let water flow down and drain away.
Scooterman wrote:Do these go open circuit at 100A then reset when current drops below? Or does it reset when internal temp drops below certain value?
I’ve never come across them before.
Burgerman wrote:No they go bang and thats it!
Irving wrote:Scooterman wrote:Do these go open circuit at 100A then reset when current drops below? Or does it reset when internal temp drops below certain value?
You're thinking of polyfuses. Sadly they don't come in 100A+ sizes (AFAIK).
Burgerman wrote:3. Unless working very fast and carefully, there is a high probability of having solder wicking up the wire, making it stiff and more prone to breakage at the end of where it wicks....
But thats just as likely as where it exits a connector, crimped, or soldered or otherwise if its SECURELY crimped. So I dont get that.
Also while solder isnt massively strong, it certainly is plenty strong enough when done properly. The copper cables are not a lot stronger, and the solder area is big enough that the cable snaps first if pulled in most types of joint.
For e.g. Worst type of joint/connector, the XT 60 and 90s. I have dozens of lipo connectors soldered only, into tiny half cups, on those XT60 and XT90. They rely totally on the strength and the electrical connection of a properly done tiny area of soldered connection. We use them in quadcopters, helis, airplanes, and yank the connectors apart by the over heated cables running 100 to 150A a dozen times a day. Never saw any of mine fail ever. Even in crashes. Bent and smashed cables, even ripped off the battery. Never the soldered bit. And the soldered connection doesent get any warmer than the abused silicone cable. IF SOLDERED PROPERLY!
Users browsing this forum: Burgerman, LROBBINS, Pierro, snaker and 81 guests
