EZ LOCK Solenoid
Adapted Vehicles.
EZ LOCK Solenoid
Postby cdb0ewm » 09 Apr 2020, 14:11
The solenoid on my EZ Lock died. I just called them and they will only sell to a dealer and you know how much that will cost. Seems crazy. Any ideas on another source. Mine is so old can't see a part number/manufacture, etc
cdb0ewm
Re: EZ LOCK Solenoid
Postby Burgerman » 09 Apr 2020, 22:08
Take it out. Look for part muber or spec or measure it. Then search. Why on earth wont they sell you spares? They me sick, anything to be difficult.
Postby flagman1776 » 12 Apr 2020, 22:47
I found this image of the underside of an EZ LOCK BL-6209
flagman1776
Postby flagman1776 » 12 Apr 2020, 22:59
flagman1776
Postby Burgerman » 13 Apr 2020, 06:29
You have checked that:
1. its not jamming on the burred edges and that the mechanism moves freely?
2. electrical connections and microswitches?
3. resistance of the solenoid?
4. actually connected 12V to the solenoid directly? Because they seem pretty substantial electrically.
The only thing that can realistically burn that out would be if it remained powered up due to mechanically jamming (the burred edges, bolted to tight, etc, or a failed or incorrectly positioned microswitch. Its more likely a bad switch, bad connection, or mechanical positioning or friction problems. Operate it on the bench with a screwdriver instead of the chairs bolt. And test the solenoid alone.
Postby sacharlie » 13 Apr 2020, 14:47
Solenoid does nothing more than the manual release cable does. Used that for years.
sacharlie
Postby Burgerman » 13 Apr 2020, 20:05
When your cars on fire after a bump, its best to have 2 methods in case one fails...
Postby Burgerman » 13 Apr 2020, 20:06
When your cars on fire after a bump, its best to have 2 methods in case one fails... When you pull and that cable snaps or its nipple falls off.
Its bad when your nipples fall off. :shock: You should watch final destination.
https://forums.roadbikereview.com/attac ... _cable.jpg
Postby cdb0ewm » 12 Feb 2021, 01:27
Well after many gyrations in that EZ Lock wouldn't sell the solenoid directly to me and the local dealer wanted $200+ to replace it, I finally figured out who made it for EZ Lock. When I contracted them, not only wouldn't they sell me one but said the specs were proprietary by EZ Lock and they couldn't help. After a little research I found the solenoid below on Amazon. I had to mount it slightly differently but it works great and was cheap.
cdb0ewm
Postby stevelawiw » 12 Feb 2021, 10:41
Excellent thread chaps, full of useful info. I too have used the manual overide for years and never bother using the electrical method.
But Burgermans advice about having more than one means of exit hit a nerve, as I'm thinking of installing some with just the manual method of release, just because it's easy.
GM Coachworks quoted me almost £5000 to fit two in a new Ford Custom Colorado czy
stevelawiw
Users browsing this forum: No registered users and 29 guests
