I understand
I am a few minutes late ...sorry!Burgerman wrote:Woody will be along in a minute...
LeeRC wrote:Hello All
I am hoping I can get some help with my TGA Vita-X (Heartway S12X Monster) controller The S-Drive S200A . I bought the scooter in nearly new condition a couple years ago after the owner barely used it, but the thing was he had it programmed and dumbed down pretty bad. I have looked into creating the leads needed (thanks to this forum) but the software is impossible to get and a so called engineer said the charge just to come out would be £95 and the programming a further £500 but he seemed very shady.
I really want its response increased and perhaps get it back to factory settings and then set it up the way I want it. I am savvy with electronics so the lead shouldn't be a problem if pointed in the right direction.
Thanks in advance for any help if possible.
Cheers
Lee
Stan dup wrote:We ended up removing the speed limit, was just a case of removing the speed sensor near the rear right wheel. She moves now, not sure how fast as speedo doesn't work now.
Just have to worry about the heat now, gets warm.
Didn't want to mess around with more batteries unless we really have to. Otherwise we would have to redesign the kart to accommodate them.
Thanks for the help buddy.
woodygb wrote:LeeRC wrote:Hello All
Cheers
Lee
Here is a pic ...there are more scattered through out this thread...use the later ones... 2018 onwards.
Check your messages
Ummm ...I think that you mean resistor not cap.Better get the cap and diode ordered now.
Stan dup wrote:Ah! ...So you retain the original tiller head ?
Yes we have retained the tiller head and front board.
I suspect that it is possible to either reprogram the board inside the tiller head or perhaps substitute a 8 mph sensor for the 6 mph.
Looking at the wiring diagram there are two ports, Com 2 TTL, and Com 1 RS4B5.
I will try to reprogram through this socket.
Would i need a specific program?
woodygb wrote:Ummm ...I think that you mean resistor not cap.Better get the cap and diode ordered now.
YesWould you see that as a decent price?
How munch faster u think it goes can you still slow it down ?
Users browsing this forum: Yennek and 288 guests
