Postby Burgerman » 26 Apr 2019, 11:10
What voltage is the supply?
12A max, @ 26.8V to XLR? Would be about right?
So you need a CC/CV charger that will work from a higher voltage like 36?
Postby shirley_hkg » 26 Apr 2019, 11:53
12A max @28.2V via XLR .
Supply battery voltage between 29.4---23.0V
Postby Burgerman » 26 Apr 2019, 13:55
Then it will need to be a buck and boost system like the PL8...
28 OR MORE IS TOO HIGH. iT WILL WASTE A TON OF POWER TRYING TO CHARGE A SET OF 95% FULL BATTERIES AT cv, AND BE WASTING ALL ITS ENERGY IN GASSING AND RECOMBINATION. Sorry about caps!!! You want it to contribute range not to desulfate the batteries idealy. The charger can do that later on.
Postby optical10 » 27 Apr 2019, 10:48
Burgerman wrote:This is really worth watching.
Tesla batteries.
youtu.be/TdUqQZC2dcE
@Burgerman Thanks, well worth the watch, way to shake up the car industry in only 15 years https://youtu.be/lyyeY8jO5UM, off to watch part 1.
If only tesla made a PowerChair or Toyota iReel https://www.topgear.com/videos/top-gear-tv/richard-hammond-drives-toyota-ireel-series-12-episode-2....off to tweet elon musk :dance
Revolectrix PL8
Shirley modified ZXD2400 PSU
optical10
Postby shirley_hkg » 25 Dec 2021, 04:25
I've made 10 of these compact powerbanks for wheelchairs.
24V50A, hup on hop off anytime , any chair .
Postby Burgerman » 25 Dec 2021, 08:43
Interesting.
Postby fishinjunky » 26 Dec 2021, 16:05
Impressive looking good :worship
Postby shirley_hkg » 01 Feb 2024, 04:57
They are popular and need more units to meet the demand. I want to make 5 sets this time, with 21700 cells(6P7S), going after slim outfit.
Gonna pick a cutoff voltage.What will be the difference in DOD with 3.3V and 3.6V respectively ?
Burgerman wrote:Discharge to lowest 3.6V (3.7V for safety which will be about a weeks use earlier)
Postby Burgerman » 01 Feb 2024, 09:38
Lifespan (unknown but very significant) and around 10% range.
Postby shirley_hkg » 09 May 2024, 11:09
Burgerman wrote:Or you can use say 8S and 4p 21700 cells and build a physically small firework 20Ah 35V battery in a small bag carried on the chair push handles. And use this, to give say constant 27V and 3 to 5A limited CC/CV charge via XLR all day long. So adding 50% or 60% to the range. https://www.ebay.co.uk/itm/226087828265
Been planning to build one to lend out myself for years. Never get around to it!
It would extend the lifespan of lead by a long time, maybe double or better if set as suggested above.
4 or 5 Amps isnt enough for continuous rolling. But it would still more or less keep up as it catches up when you stop for a few mins or eat etc.
Remember that 4A charge is 20Ah restored every 5 hours. About the rate most people use up the battery. So low DoD average.
Thank your advice.
Sticking to 24V is to cater for recharging with stock charger of one's own.
A buck-boost inverter is used. It has small footprint of 80*55*20(mm), 5-48V/0-20A
Postby shirley_hkg » 23 Jan 2025, 09:53
Found some obsolete LFE pouch cells in garage. Converting it to another 45Ah power bank for wheelchair. cheers
Users browsing this forum: Bing [Bot] and 92 guests
