Burgerman wrote:Have you resisted the temptation to touch your tongue on the terminals?
Burgerman wrote:Probably. Has it reached the 3.600V CV?
fishinjunky wrote:Burgerman wrote:Probably. Has it reached the 3.600V CV?
Yea it was showing 3.6v and around 7amps. I have the current set at 35amps and end current is 1% and end voltage is 3.6v. I couldn't read IR without the balance leads and for cut off voltage I think is read through the balance leads. Is that why it didn't cut of at 3.6v in cv phase?
Is this correct?
The charger starts with cc " constant current" then once the current starts dropping its goes into cv phase " constant voltage "
If it's pretty much fully charged when I start the çharge will it go right to the cv phase. Which is why only 7amps from the start?
Burgerman wrote:They are full when current drops to a very low level. Like around 1/2A. They are 99% or more full now.
Burgerman wrote:Every cell manufacturer is different. What was the current when it stopped falling? Set termination to say 10% greater.
But it should be lower than 6A! Dishcharge it by 10Ah and then recharge it. Note the current when it stops dropping.
It looks like charging with a CC /CV psu.
Hobby chargers do it the other way. They charge at higher volt to achieve high amp. They charge for a while and stop to measure cell volt, so not to overcharge it .
It's strange that a seller will store or ship with 100% SOC.
fishinjunky wrote:all cells show IR 1.0
is that good?
fishinjunky wrote:Cell number 1 is charging its says 3.35v and has put in 46ah so far but only charging at 14amps but I have it set at 35amps?
It's been charging for 3hr 15min
Burgerman wrote:How many cells?
The one that shows 3.37V is not full. I have no idea why the charger is not charging at the rate you set unless the othr cells in a pack are almost full. To be honest I cant make sense of that display.
steves1977uk wrote:Also it says the PSU is delivering just 2.2Ah??? The info screen is just too messy to understand what is actually happening.
fishinjunky wrote:In conclusion it's the alligator clips not giving a good enough connection
Users browsing this forum: No registered users and 147 guests
