It's my PC @home, that worked fine last year.
Thanks for any advice.
Burgerman wrote:Set it to a lower com port, 8 or less.
It's my WIN_10 PC @home, that worked fine last year , and it was com 10 too.
Thanks for any advice.![]()
woodygb wrote:Shirley ... The only advice that I can give is to check for a physical problem ... i.e. Broken connections.
So .. open the box and look at the wires going in and out from the board and also check the wires inside the DB9 Socket.
Checked all 6 connections are good.
I have the USB converter installed.
Plug in your lead. Joystick shows an inhibit.
Connect the other end to USB converter. Inhibit goes away. Is it normal ?
woodygb wrote:Finally try a different RS232 / DB9 - USB cable.
david1566 wrote:any one got a lead for a pride micro glide 3 wheel mobility buggy it has a s drive controller not sure how to connect a programming lead to it
david1566 wrote:could you make me two leads for a s drive controller from curtiss Wright
one with the xlr connector and one with a molex ( mini fit junior 4 way plug )
david1566 wrote:the programming lead turned up today thanks
It is recommended that the driver be backdated to 3.2.0.0 if:
A - A yellow warning triangle appears under 'Ports' or 'Other Devices'
B - The Prolific 'Phased Out' message appears
Users browsing this forum: No registered users and 52 guests
