Where to find PGDT programmer software
Re: Where to find PGDT programmer software
Postby cata300 » 09 Sep 2021, 20:14
Hello!
Could someone help me with Industrial Software for a Solo controller?
I have a Meyra Cityliner 410 and its max speed is very low.
Thanks.
cata300
Postby woodygb » 09 Sep 2021, 20:59
Done
Postby ERRWatti » 10 Sep 2021, 11:44
I'm also having difficulty locating the software, it would be great if you could send me a link too!
ERRWatti
Postby woodygb » 10 Sep 2021, 12:25
Check your messages
Postby dexter16 » 10 Sep 2021, 13:20
Please could you also help me with the software? Thank you very much.
dexter16
Postby midiano » 15 Sep 2021, 17:39
Hello I'm currently searching for the software to edit the parameters in my mobility scooter. I've searched around but couldn't find it. If you got time I'd greatly appreciate it if you could help. :)
midiano
Postby rex_tech » 15 Sep 2021, 23:31
Hello,
Could you help me with programming software for S-drive 200A controller for RZ1500 scooter, really need adjust a few parameters, otherwise my uncle destroys all around.
thanks in advance
rex_tech
Postby KaMA » 04 Oct 2021, 21:52
I'm tested Solo controlled mobility scooter 36V battery. It's works. But still output only max 24V to motor. Same as using a 24 volt battery. I remember seeing in the manual the 36 volts mentioned as well as the maximum motor voltage setting. Temporarily tried a 36V 30A Chinese ebike controller with no electric brake or reversing. I would like the original driver to work.
Need Industrial Software for a Solo controller to change motor max voltage settings? Maybe also raise the current limit with a few amps if possible. Where I get? Cables are not a problem.
KaMA
Postby woodygb » 04 Oct 2021, 22:57
Check your messages.
Postby KaMA » 05 Oct 2021, 16:39
Great :thumbup:
The programming software helped. Original motor output 22Vdc maximum voltage changed to 36Vdc. The former gps measured at 12km/h turned into a speed of 20km/h. Speed measured on a ride with a load of 36V 70Ah lead-acid battery and a 100kg man. And the engine doesn't even overheat. Towards the end of the week, 4.10/3.50-5 tires will be replaced with larger electric wheelchair tires. They have the same 20mm shaft.
When the maximum voltage of the motors was increased, the low battery indicator light also seemed to rise for the battery. It seemed that with the 30-40Vdc setting of the motor, the low battery indicator flashes at approx. 35Vdc battery voltage.
KaMA
Postby woodygb » 05 Oct 2021, 17:10
Excellent! :thumbup:
Postby Porkchops » 14 Oct 2021, 11:53
Hi Woody any chance of getting the software for the solo controller on my mini crosser?
Porkchops
Postby woodygb » 14 Oct 2021, 11:59
Yes...check your messages
Postby stepfen » 16 Oct 2021, 17:21
Anyone can help me find the software for the PG VR2 controller ???
Thanks a million.
stepfen
Postby MartinQuantum » 03 Nov 2021, 11:39
Hello, would anyone be so kind and send me the link to the VR2 programmer software OEM version? Many thanks!
MartinQuantum
Postby woodygb » 03 Nov 2021, 11:41
Done...check p.m.
Postby rambomira » 03 Nov 2021, 13:50
Hi, please anyone send me link on OEM programmer. Thank you so much.
rambomira
Postby mateyboy » 18 Nov 2021, 00:27
Hey guys could someone please send me the link also?
Thanks in advance :)
mateyboy
Postby Toylander2021 » 03 Jan 2022, 19:51
Any chance of a working link for s drive programming thanks in advance
Toylander2021
Postby woodygb » 03 Jan 2022, 20:07
Done
Postby Jinks02 » 01 Feb 2022, 09:11
I need to swap the S-drive controller on my mobility scooter as the old one has given up the ghost, Could I please get a link to the programming software.
Many Thanks in Advance
Jinks02
Jinks02
Postby woodygb » 01 Feb 2022, 09:15
Check your messages
Postby Jinks02 » 01 Feb 2022, 09:16
Thank You much appreciated
Jinks02
Jinks02
Postby Jinks02 » 01 Feb 2022, 12:49
Quick Question
If I'm making a lead from a USB serial adaptor to a "ATX" 4 pin Molex plug can I just connect pins 3 & 4 on the Molex plug to the Tx & RX of the USB lead, or do I still need to bridge pins 3 & 4 and add a diode to control the flow.
Also do I need to set a baud rate and flow control anywhere ?
Once again
Many Thanks
Jinks02
Jinks02
Postby woodygb » 01 Feb 2022, 13:27
There is no need to play with any settings...the cable should just work.
Connecting RX and TX from the Molex to the USB TTL Serial Adapter will work and you will not need the diode or resistor.
Postby Jinks02 » 01 Feb 2022, 14:02
Brilliant Thank You
Jinks02
Postby woodygb » 01 Feb 2022, 14:06
Pic.
Postby AlasiaMedium » 19 Mar 2022, 10:42
Hello,
I am interested in the Link for the Software too. Could someone please send it to me?
Thanks in advance.
AlasiaMedium
Postby AlasiaMedium » 19 Mar 2022, 12:30
Ok. I have the program now. But I also have a problem. The program always show "COMMS INACTIVE". However. The program sends requests to the controller and the controller does answer. But there seems to be a timeout error on the port.
Therefore my question: Do I have to use Win7 for this program? I thought I saw the standard Win10 backround in one of the screenshots here.
Screenshot of the communication log:
https://i.imgur.com/KdshTky.png
AlasiaMedium
Postby woodygb » 19 Mar 2022, 13:38
Which controller?
What lead / cable are you using for programming?
Some of the larger amperage S-Drives have been reported as problematic.
I.E. The S Drive TX signal is not pulling low enough....The “Low” signal on these S-Drives must be pulled down around 1.3 volts.
Users browsing this forum: emilevirus, Seafighter and 474 guests
