Burgerman wrote:Then as hard as it may sound you do not have enough capabiity in your hand or control to drive with a joystick. Those settings are glacial. Practically unusable as the chair is so very sluggish.
How is it possible that you find these settings too fast?
You dont want the chair to move at all?
Can you video the chair with you controlling it with the settings above? So I can see what we are talking about?
Then, after that, try adjusting forward acceeration ONLY set both min forward acceleration and forward acceleration even lower and testing that.
Then if thats OK then do the same with turn speed. And minimum turn speed. Set them both to the same lower figure.
Then report back. I find it increadible that the settings as they already are can possibly be too high! The chair almost doesent move.
Do ONE SETTING at a time. Also do not lower compensation.
DO NOT touch turn acceleration, or turn deceleration either!
Burgerman wrote:Do a video of you driving around for 5 minutes.
Burgerman wrote:No do each oe individually, and test tem all individually to find out what is best for your usage.
I have forward acceleration set to 100 on my chairs because I like to be able to go when I decide, as hard as I choose to do so. because the joystick is proportional. You cant do that because you use it as an on/off switch. So set that to whatever forward acceleration you want.
Do the same with every one of those settings. EXCEPT for turn acc, turn dec, minimum turn acc minimum turn decel, leave these 4 set HIGH.
Burgerman wrote:Your idea of "jolting" is what everyone else calls gradually moving at glacial speed. If you want it not to move at all then just turn it off. Those settings are the best and slowest possible that can realistically be used.
If thats too much for you then I do not know what else there is to say. Other than as previoulsy asked, HAVE YOU FIXED THAT SEATING ???
Because youare sat too far forwards, and the seating wobbles back and forth. And as already said you must fix this FIRST. Then you need your arm or hand immobilising so that its stays still and doesent "jerk" the joystick.
Then try the same settings again. WAY too slow for any normal use. If that doesent sort your problems then theres no solution. You cannot fix mechanical or incorrect seating positions, or lack of rigidity, or CG problems by setting all your programming settings to 1...
Also why are you so scared of it moving? (jerking)?
q700m wrote:sorry, but 1 refers to the lowest value of the ALL SPEED profile and 5 to the highest value of the same profile
when I move the joystick to the right or left, the chair should not move.
on the other hand, if I hold the joystick down to the right or left then the chair can also move quickly.
I don't know if you can do that?
Burgerman wrote:OK I thought you were using some special one.
Thats OK.
Heres what I thought was your problem
You need to download this to your desktop first before playing.
One has a square restrictor, the other round.
http://www.wheelchairdriver.com/gopro/JStypes.mp4
So now I need ONE video, of you using the chair around the house and in a straight line at speed.
We cannot go any further unless I see this clearly.
Users browsing this forum: Bing [Bot], emilevirus, LROBBINS and 107 guests
