It was suggested on a discord that what you actually get when reading from a chair using a dealer dongle is all of the dealer read, read/write, and write parameters, as well as all of the OEM read and read/write parameters. But any OEM parameters marked write, can only be read by OEM, but written by dealer so that dealers can write manufacturer updates, but cannot actually go into the written PM and see what those parameters were that just got written. It was further suggested that when you attempt to read those parameters with a dealer dongle, what gets written into the file is not the parameters actually stored on the PM, but the default settings stored in the programming software.
So to test that, one would need to slightly change every parameter away from the default. Then read it with dealer dongle and check every parameter to see what it read back.
In my case, I want to pull the images of the wheelchair used in the seating menu because my seating is very different. I want to see what format those images are in so I can create my own custom seating images.
I have seen and driven a chair with completely new display UI on a CJSM2. So I know it is possible. I just don't know how.
slomobile wrote:It was suggested on a discord that what you actually get when reading from a chair using a dealer dongle is all of the dealer read, read/write, and write parameters, as well as all of the OEM read and read/write parameters. But any OEM parameters marked write, can only be read by OEM, but written by dealer so that dealers can write manufacturer updates, but cannot actually go into the written PM and see what those parameters were that just got written. It was further suggested that when you attempt to read those parameters with a dealer dongle, what gets written into the file is not the parameters actually stored on the PM, but the default settings stored in the programming software.
clietz wrote:Hi, I'm new to this site. Not sure if you can help me. I just purchased a mobility scooter S19F+ Bio, 4 wheel scooter.
I was trying to connect to the 3 pin plug to use the R-NET programmer, using resistor and diode configuration. Cannot communicate.
I think I need the DONGLE to connect as Windows doesn't see any drivers for the software. Hope someone understands. My scooters maximum
speed is set to 6 km/h. and I wish to increase to 8km/h. I think that 5 mph to 7 mph? Please advise.......
I have a second-hand Meyra Optimus 2 which I got to replace my old second-hand Meyra Optimus.
The old Optimus was Canbus based and easy to tailor, not so much the R-Net based Optimus 2.
But I will get there with the help of all the excellent information already available here.
Nope.
Much of that is custom - not r-net - but myra stuff. That the normal software cannot program or display. Plus theres a bigger problem. The power module used is a custom single channel one. That is not properly configurable by the normal dual channel tank steer power module programmer. So at best you will be able to make a few changes, but not the ones you need. The myra is a scooter. With single channel motor, and a servo system for steering. Its not a powerchair as such.
Users browsing this forum: Andrey, LROBBINS, saker98 and 581 guests
