Burgerman wrote:More likely you have not configured it correctly.
What is the CURRENT you have set for it to transition from 28.1 to 27.0V? This needs to be around 0.3A on a cyclic overnight charge. Set this any higher like 1A or above and it will go straight to float if the battery is nearly full. And then take another 16 hours to complete the charge bare minimum.
Burgerman wrote:Once set corectly it will do this.
Note this is a full battery! Well it was half an hour ago.
Set to transition at .2A here. And to float at 27.2.
https://www.wheelchairdriver.com/gopro/3stage.mp4
Preset value of resIdual current to trigger to floatBurgerman wrote: the CURRENT you have set for it to transition from 28.1 to 27.0V? This needs to be around 0.3A on a cyclic overnight charge. Set this any higher like 1A or above and it will go straight to float if the battery is nearly full.
I am using my old Permobil C500 now so I could try to fully charge the newer F5. It stayed at 0.44 amps at 28.2 for about 12 hours. When the main power switch was turned off, it went immediately to 0.1 amps then to float at 27v. But I'm not sure if it's actually still charging when the main power switch is off. I don't know if that disconnects the joystick power input from the battery.
Burgerman wrote:What main power switch is this?
Unless you are talking about the chairs ressetable breaker?
That switch disconnects the battery from the whole chair. At which point the charger if in use will be powering the chair... And whatever current it reads is then what the chair takes to run its electronics.
Burgerman wrote:No it just disconnects the battery. The charger is then doing the job of the battery. DONT try moving the chair, it could hurt the thin wires in the joystick. If you turn the chair on then on a normal R-Net chair the joystick will light. And then draw a few mA like maybe 100 or 150 depending on actual modules fitted. Then when its turned off it will be taking maybe 10mA.
I recently squeezed 160Ah into a F5VS. I recalled the breaker got between the 2 lead bricks.jefferso wrote:My C500 has an SB50 wired directly to the battery, so even when the main power is off, it can still charge.
shirley_hkg wrote: I recently squeezed 160Ah into a F5VS. I recalled the breaker got between the 2 lead bricks.
It will be in open circuit , if you flipped that breaker off, and ZXD is charging nothing.
How do we know that chairs are only using voltage to estimate state of charge? Disassembled firmware? Circuit analysis of a PM?
jefferso wrote:Do you have any photos of the pack? I want to make a lithium pack for my F5VS and am trying to figure out the best configuration.
I used 2 of these semi assembled packs and stack them together.
Burgerman wrote:8x 230Ah cells shld fit in the storm 4 ?
Users browsing this forum: Jay_x, Juggler258, korn and 109 guests
